How To: Search for Submitted Feature Suggestions
Using Search in the Feature Suggestions section will help you find existing suggestions in which you might be interested!
How do I search for submitted Feature Suggestions in the Fitbit Community?
FEATURE SUGGESTION SEARCH
To search for submitted Feature Suggestions in the Fitbit Community, enter related keywords in the search field at the top left of the Feature Suggestions homepage. A list of relevant Feature Suggestions will automatically populate in the dropdown menu. Click on one of the results to open its Feature Suggestion thread.
To see a more comprehensive list of results, enter your keywords or phrases completely, then hit Enter or click on the magnifying glass. A new page will open, listing all related search results. On the Advanced Search page, you can filter these results using the categories to the left (location, author, date, etc.)
Note that accessing the Advanced Search through the Feature Suggestions board will immediately limit your search to the Feature Suggestions Board. If you access the Search function from another board in the Community, you must select the box “Ideas” under “By type of post” in order to narrow your results.
If you are looking for the Feature Suggestions with the most votes or comments, use the dropdown menu on the right under “Sorted by” to locate the most highly voted or viewed content, or to view the most recent Feature Suggestions related to your Search terms. Clicking the “Advanced Search” option will allow you to further refine your criteria with the selected categories.
3 REPLIES 3
Thanks FitbitCommunity. Helpful and great advice as always.
Stepping in the U.S.A. since September 2013. Android 9
Please add a second hand to all clocks on fitbits. A lot of medical employees would like to where these but will not spend the money on something that they can not wear at work. All doctors offices and hospitals require their employees to wear a watch with a second hand in order to take accurate vitals. If this can be added, then sales would increase. Thanks
@MedicalMama If you read the post you would see how
This is a requst for Blaze. Not knowing what you have its hard to tell.  But if you the read the first post you can search
https://community.fitbit.com/t5/Feature-Requests/Blaze-Seconds-Hand/idi-p/1477404
Community Council Member
Wendy | CA | Moto G6 Android
