03-10-2014
06:40
10:43
03-10-2014
06:40
10:43
Where is the INBOX?
Where does it go?
I open a message whenI see a red flag next to my name. If I close the message, there is no INBOX or Mailbox button to go back a view messages. I can only see the posts that I have created.
@SunsetRunner wrote:Where is the INBOX?
Where does it go?
@SunsetRunner When you click on your name, you do see the posts you have made. I am looking at mine on the computer.
Go to the right and click "View Inbox" and you will see your in box with messages and your sent box.
Where does it go?
@SunsetRunner Just sent you a message. Check your inbox.
Best AnswerTry this link - click
I am doing this and seeing this with my computer. You using a phone?
@SunsetRunner It sounds like you're looking in the right place. Click on your username, just to the left of "Settings". Then click "View Inbox" at the top-right. You can also use the link provided by Odyssey above.
