12-08-2021 14:22
12-08-2021 14:22
I installed fitbit charge 5 and added my credit card for the 6 months free premium trial, but it won't open and gives me a message: purchase not allowed, why???
12-08-2021 14:30
12-08-2021 14:30
Hello @Rose2022
I'm not sure why and am only guessing.
Could it be a Credit Card problem?
If not, is your Charge 5 outside the time limit for the free Premium trial?
Another possibility to consider is whether you already have a paid subscription and want to switch to the free trial. If that's the case, you need to cancel your current subscription and then when that's stopped, you can start the free trial.
I've copied a link to the Help Pages for Premium and I'm hoping something there might help you.
I hope that helps a bit.
Best Answer12-08-2021 15:13
12-08-2021 15:13
12-12-2021 09:06
12-12-2021 09:06
Thanks for your answer, nothing worked until I cleared my cache, my data, re-installed the app, re-entered my credit card and more or less started from scratch.
Not even their customer service could help me. 🙄
But at least now it is working.🙂
Rose
12-18-2021 12:49
12-18-2021 12:49
Thanks Rose2022,
I have been having this problem for more than a month and the folks in Fitbit Support were clueless as to how to fix it. They last suggested that I contact Google to resolve the problem. I did as you directed, clear app cache, data, uninstall, and re-installed. Everything works now.
Best Answer12-18-2021 14:06
12-18-2021 14:06
