04-26-2020 05:06
04-26-2020 05:06
Just bought fitstar premium yoga and it has no sound? No music or tip voice I have turned up audio. Anyone know how to fix this?
 Best Answer04-28-2020 12:25
 Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              04-28-2020 12:25
@EmilyR1 Welcome to the Community. Sorry for the delayed reply.
It's pretty weird that you're not getting any sound, music or tip voice. I would like you to log out from your app and force quit it. After this, please log back in and check if you have these options.
Also, keep in mind that it requires iOS 8.0 or later.
Keep me posted!
 Best Answer08-10-2020 09:46
08-10-2020 09:46
I’m having the same issue. I logged out and forced stop and it still is not working. I’ve turned the volume for coaching tips all the way up and it still has no sound.
 Best Answer08-11-2020 12:26
                              08-11-2020 12:26
@Wackim59 A warm welcome to the Fitbit Community. Thanks for the details mentioned.
I appreciate the troubleshooting tried prior to posting. In this case, I've shared your post with our Support team and someone will reply to you as soon as possible. Keep in mind that due to recent events affecting our operations, we may take a bit longer to get back to you.
I'll be around if you have any additional questions.
 Best Answer08-13-2020 20:27
08-13-2020 20:27
Is there a solution for this problem?
 Best Answer08-14-2020 11:56
                              08-14-2020 11:56
@Margarita1510 A warm welcome to the Fitbit Community. Thanks for getting in touch about this.
I would like you to confirm you've double checked that the Coaching tips on your FitStar Yoga are "On" and that the volume has been properly adjusted. If you have checked this but you're still not hearing any sound, please log out from the app and force quit it.
Let me know how the troubleshooting goes. I'll be around if you have any additional questions.
 Best Answer08-20-2020 02:39
08-20-2020 02:39
Hi. I have the same problem and have tried all recommended actions. Even de-installing and reinstalling the app. Nothing works. The app has no sound and the settings are correct. What can be done?
 Best Answer08-20-2020 11:57
                              08-20-2020 11:57
@NuriaNI A warm welcome to the Fitbit Community. Thank you for the troubleshooting tried prior to posting.
I appreciate that you double checked that the settings are correct. In this case, I've shared your post with our Support team and someone will reply to you as soon as possible. Keep in mind that due to recent events affecting our operations we may take a bit longer to get back to you.
 Best Answer10-10-2020 05:32
10-10-2020 05:32
may be it is because an update or something! I use FitStar yoga since a looooong time and it is a new problem. Please reply/fix it soon
10-10-2020 11:18
                              10-10-2020 11:18
@CaroGau A warm welcome to the Fitbit Community. Thank you for getting in touch about this.
One factor that may affect the volume of your session is the mute button on your device that is accidentally being in silent mode.  Another way to test if you have your mute button enabled is by plugging in the headphones into your device and then test the app. If you can hear sound in that scenario, that means mute is enabled on your device.
