11-28-2020
04:31
15:03
SilviaFitbit
11-28-2020
04:31
15:03
SilviaFitbit
I just purchased the new Fitbit Sense and I tried to start my 6 month Premium Subscription. When I go to start it, "Purchase Failed" pops up and it won't let me navigate that tab at all. How do I redeem my full 6 months?
Best Answer12-01-2020 15:02
12-01-2020 15:02
@Wardan10 A warm welcome to the Fitbit Community. It's great to hear that you have a Fitbit Sense.
Keep in mind that your Premium trial will activate as soon as your Fitbit Sense is set up to your account. If it's set up then log out, force quit it and try again.
If you're still experiencing this please attach a screenshot of the message you're getting to your next reply.
Let me know how it goes.
Best Answer12-02-2020 17:09
12-02-2020 17:09
I tried and it still is doing it.
12-03-2020 10:35
12-03-2020 10:35
@Wardan10 Thank you for getting back. I appreciate the screenshot attached.
In this case please log out from the Fitbit app, force quit it and log back in. After this log back in and activate your Premium trial.
Best Answer12-03-2020 14:58
12-03-2020 14:58
I just logged out, force quit it and I'm still getting the same message.
Best Answer12-04-2020 12:52
12-04-2020 12:52
@Wardan10 Thank you for getting back. In this case, I've shared your post with our Support team and someone will contact you as soon as possible.
Have a great weekend.
Best Answer04-25-2021 06:27
04-25-2021 06:27
Hello! I am having the exact same issue in the same situation. I just bought a Sense and when I go to the Premium subscription page, I get the purchase fail screenshot above.
Thanks for the help
Philippe.
04-27-2021 12:06
04-27-2021 12:06
@apoufortin Welcome to the Fitbit Community. Thank you for the troubleshooting performed.
I'd like you to try the following:
- Log out from the Fitbit app
- Clear cache
- Restart your phone
- Log back in
- Activate your Premium trial
Hope this helps.
Best Answer04-27-2021 15:03
04-27-2021 15:03
Hi Silvia. I tried was you suggested and it did Not for my problem. Now, when I select the Premium tab, I get spinning icon and, after a few seconds, the same error message, purchase failed.
Best Answer04-27-2021 18:55
04-27-2021 18:55
After clearing the cache, the app clearly tries to fetch my subscription information for the server (the spinning cercle) before failing. My guess is bad data on the server associated to my account, for which I cannot do anything. So I hope the moderator here can check this out for me or put me in touch with tech support 🙂
Best Answer04-28-2021 13:42
04-28-2021 13:42
Well, I contact the support team and they helped me fix the issue. All is working now. Thanks!
Best Answer05-04-2021 11:04
05-04-2021 11:04
@apoufortin Thank you for keeping me updated. Glad to hear that our Support team was able to help you fix this.
Have a nice day.
Best Answer06-02-2021 13:33
06-02-2021 13:33
hi apoufortin, how do you resolve the issue?
how the support team resolve your issue??
thanks and regards
Best Answer06-03-2021 10:57
06-03-2021 10:57
I used the Help and Support section in the app. When you click Contact Support, it will make a call to the support line directly within the Fitbit app.
I don't remember all the steps I had to take. I remember that I had to unpair the watch, then press the left button on the watch to get it to reboot. Then, there was a way to re-connect the watch to the phone as a new device, telling the Fitbit app that this was a replacement of the old watch (to keep the settings). Doing that, I had to go through the setup process and at the end, when it asked me if I wanted to activate my 6 months trial, I was able to say yes. From then, the Subscription page started working.
Hope this helps you!
11-27-2021 08:11
11-27-2021 08:11
I was able to solve this issue by logging out of my playstore account, uninstalling Fitbit, restarting tm Fitbit tracker, sign back in to my playstore account, install Fitbit, and error pop up was gone. I signed up without issue.
I believe this pop up is caused by the play store blocking the transaction.
Hope this helps!
Best Answer01-25-2022 23:27
01-25-2022 23:27
I'm having the same issue and have followed your steps on here to no avail.
05-05-2022 21:53
05-05-2022 21:53
Can anyone help me contact support? I have a Charge 5 with the same issues. Following these steps does not solve the problem
05-06-2022 05:07
05-06-2022 05:07
You have to open the Fitbit app, then click on you icon, top left. Scroll down and select Help & Support. Then select Contact Customer Support. This will call support.
Hope it helps!
Best Answer12-02-2022 08:31
12-02-2022 08:31
Wardan10, I had the same exact issue. Fooled with it, chatted with tech support and eventually called tech support. They had no idea. While on hold I noted my credit card was linked to my Google Play account. I went to Google Play and into the payment options. I clicked edit on my credit card and noted the security code was missing. I typed it in and saved it. I was then able to get the subscription going before the tech got back on the phone.
Cheers,
