How can I tell if Premium is activated?
I ordered the free trial of premium an hour ago. How can I tell if it is activated - I think I should see something new but both the app and the web portal look the same to me.
1 REPLY 1
@allan473 Hi there. Thank you for the details mentioned.
The Fitbit Premium is a personalized resource in the Fitbit app that helps you stay active, sleep well, manage stress, and more. Check out the following features that you should see on the Discover tab of the app:
- Guided Programs
- Challenges and Adventures
- Workouts
- Mindfulness
If you're able to view all the features described above, this means that your subscription has been successfully activated.
Learn more about Fitbit Premium in this article
Hope this helps.
