11-23-2021
05:12
15:55
YojanaFitbit
11-23-2021
05:12
15:55
YojanaFitbit
Hi,
Is anyone aware of a way to listen to sleep meditations with "do not disturb" switched on on the phone?
I want to be able to use the sleep meditations but want the screen to be off and for DND to be active so that I can fall asleep without being disturbed by notifications etc.
Otherwise the sleep meditations are useless.
Thanks for any advice!
Best Answer12-03-2021 15:57
12-03-2021 15:57
Hi there, @Qlqlp. Thanks for trying to troubleshoot the inconvenience with your meditations before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
It depends on how your phone works, since most of phones mute videos from all apps once DND is on. You need to check the settings on your phone and see if it has that specific option.
See you around.
