Sleep animal does not corrospont with the month overview of my Sleep
The overview of my sleep animal of this month does not at all correspond with my month overview of my sleep.
Does the sleep animal function only take this month or does it take the data of several months?
Moderator Edit: Clarified subject.
2 REPLIES 2
Hi @Eliaquim   Your Sleep Animal comes from the only the previous month's sleep data.  There are six sleep animals.  Tap on your Sleep profile tile, then scroll to the bottom of the page.  You will see an overview of your sleep animal.  The other five are below it.  If you think there is an error, you can give feedback to Fitbit in the Fitbit app, if you have a Google account.  Tap on your profile picture, then Send feedback.
There was a bug a while ago where the purple You dot was in the wrong place on the graphs.  I don't see that bug now.  If you think there is a bug in your graphs, can you add some screenshots?  That can be reported as a bug.  Please note if you use an Android or iPhone.
I use an iPhone and mine is spot on.
I also moved this thread to the Premium forum, a better fit for this issue.
Laurie | Maryland
  this are some examples, i use Android, it is like this graphs and this sleep animal are from different persons.
