10-12-2019 05:20
10-12-2019 05:20
After updating my dashboard, I'm unable to find the graph that shows active and very active minutes.
Where can I find that? I miss seeing those results. I still see my total active minutes for the day, but not the graph that breaks down the type of minutes.
Before updating, it said I wasn't able to go back to the old dashboard.
10-12-2019 13:00
10-12-2019 13:00
Hello @mona991
Welcome to the community. I hope I understand your question correctly. I believe your talking about the bar graph showing your active minutes on the online Dashboard. Go to your Dashboard and double tap the bottom corner of the tile showing your total active minutes. Once you double tap it you will see a very small”see more” prompt appear. Tap that prompt and it will reveal the breakdown of your active minutes. To answer your question about reverting back to the old Dashboard it is not possible.
😃 Please let me know if this did indeed give you the best answer to your question.
10-12-2019 19:57
10-12-2019 19:57
Hi!!
Thank you SO MUCH for answering my question. I followed your directions, but that was not the graph I was looking for. The graph I'm looking for shows about one month. Each day shows with a line of color your non-active, active, and very active minutes. I really liked that graph. Do you happen to have any idea where to find that one?
Thanks again! I appreciate you answering my question and helping me! 😃
10-12-2019 20:05 - last edited on 10-14-2019 12:10 by RicardoFitbit
Hello again @mona991 Well ...maybe I do. Let’s see:
😃 Did I get it right this time? Let me know
Moderator edit: Format
10-13-2019 06:57
10-13-2019 06:57
I'm sorry, that's not it either.
This graph had three colors. Blue for when you were not stepping, yellow for light/moderate active minutes, and red for very active minutes. You could see sort of a line graph of these colors daily for about a month.
Thanks for trying!
10-13-2019 07:56
10-13-2019 07:56
Bummer I struck out twice. Maybe the graph was done away with after the newest update. I wish I could have been more help. If I come across it or learn more information I will pass it along to ya. 😃
08-20-2021 18:35
08-20-2021 18:35
Just found this now but was wondering if you ever resolved the issue?. Seems like it hit me just recently. I believ you were talking about your steps and minutes showing in green and yellow and different colors depending on exertion/speed. I miss seeing those graphs in colors and also you could tap on the graph, and it would show minutes/steps/calories (depending which section you looked at).
thanks so much.
08-21-2021 04:51
08-21-2021 04:51
Hello @Toto2 and welcome to the Help forum. You added on to an older thread and it's possible that you have a completely different question. This thread is in the web dashboard forum, but it sounds like you might be asking about the mobile app. I am an iPhone user. A recent app update caused what you are describing. I also want to add that this topic asks about active minutes and very active minutes. Fitbit really doesn't use very active minutes, except on older devices.
Can you please ask your question from the beginning? Are you referring to the mobile app? What type of Fitbit do you use?
Laurie | Maryland, USA
08-21-2021 07:33
08-21-2021 07:33
Thank you for your response. I am talking about a Fitbit app and I have it on my ipad mini4. I go to app to see the breakdown of active minutes, calories and so on, and they were showing in different color graphs according to level of activity. Now, it all is gone and it just shows totals in one color. I really enjoyed it the way it was. I truly do use an old Fitbit One. But, it works fine and I want to use it as long as it lasts. Like it better than the new models. Thanks! I hope I am describing the issue.
08-21-2021 09:33
08-21-2021 09:33
@Toto2 There is a new issue with the iOS app. Fitbit is aware of it. You should follow this thread in the iOS forum for updates. This bug is very annoying. I want it fixed, too! 😉
