06-27-2017 12:37
06-27-2017 12:37
I always used my iPhone with my Alta until I got a new work computer that has Bluetooth capability. I can't always have my phone with me on the shop floor so I sync'd my Alta to the computer to help me track stuff while at work. Now, after the weekend, I haven't been able to sync back to my computer but I can see all the information that sync'd to my phone earlier in the day. I've tried deleting the device and starting again, but all that does is just reset the Alta and I still can't sync to my computer. Help?
06-29-2017 10:47
06-29-2017 10:47
Thanks for stepping into the Forums @Garmantm!
Sometimes, the trackers bond to a particular Bluetooth device and then they can't be synced to anything else. This can happen when you set notifications or all-day sync. In these cases the first thing I'd recommend that you try is to completely turn off the Bluetooth from your iPhone and then try to sync to your computer. That should do the trick.
I'd also like to ask you, are you using a Windows 10 computer to sync? If so, have you downloaded the Fitbit app or are you using Fitbit Connect?
Look forward to your reply.
07-05-2017 09:26
07-05-2017 09:26
I am using window's 10 to sync and I'm also using the Fitbit app on the computer. I was able to try turning off the Bluetooth on my phone, but it didn't help in my trying to sync to the computer... any other suggestions? Or should I just accept that my phone is the only device I can use?
07-06-2017 10:30
07-06-2017 10:30
Hello @Garmantm! Thanks for the update.
Since turning off the Bluetooth on your phone didn't work, we could try to run the setup process through the Windows 10 app. Please follow these steps:
The Fitbit should then start working and syncing with both. Let me know how it goes!
