05-01-2023 07:15
05-01-2023 07:15
Good afternoon
Just a little confused as to why 2 fitbit devices can give very different BPM readings ?
I have been using the Charge 4 for couple years now and recently bought the Sense 2.
Just as a comparison I have for last couple weeks ware both at same times, but on different wrists.
Sense 2 on left wrist with non-dominant setting & charge 4 on right dominant wrist.
This morning for approx 2.5 hours out for 6mile walk. Walk contained following, starting with Large downhill, then mild up/down, large uphill, small uphill. 3 short breaks in-between 4 hill sessions.
Why do I get very different BPM readings? Now not sure what I can trust ?
05-01-2023 09:10
05-01-2023 09:10
@webbo1066 The Charge 4 and Sense 2 use different optical heart rate monitors (OHRM). It's possible that the two OHRMs are made by two different companies. Even if they are made by the same company, each emitter/sensor model has its own performance accuracy. If you want to know which is more accurate, then you should compare the heart rate trace with a device that measures heart rate using ECG.
Laurie | Maryland, USA
