12-25-2021 23:22
12-25-2021 23:22
Battery percentage on app does not match percentage on device (Versa Lite). Used to synch but not now. Have tried - turn off/on, restart watch, reinstall app, turn phone off/on and a factory reset - Versa Lite is 2 years old on the 30th December - warranty will
finish
12-27-2021 07:26
12-27-2021 07:26
Hello @Connie64 and welcome to the Community forum. I suspect you are an iPhone user. Many of us are having the same problem with the current iOS app. We will need to wait for a fix.
Laurie | Maryland, USA
12-27-2021 08:49
12-27-2021 08:49
01-02-2022 10:48 - edited 01-04-2022 19:05
Same Problem. iphone 8 v15.1. Fitbit app 3.52.1 (1084).
The only way I have corrected this is to log out on the fitbit app; log back in and re-sync. I have to do this each time the problem occurs.
01-04-2022 13:13
01-04-2022 13:13
Worked a treat. Thanks.
