12-02-2021 21:48
12-02-2021 21:48
Hello All,
Lately my charging port seems to be hit or miss when it comes to charging my Fitbit. Is there something I can do before buying another one? Thank you.
Coolred
12-03-2021 05:17 - edited 12-03-2021 05:18
Hello @Coolred44 and welcome to the Help forum. Does your Fitbit behave this way if you try it in different charging ports? I have a different options. Ports on my computer, charging blocks that go in the wall, etc. Please try cleaning the charging contacts on your Fitbit with some alcohol and a toothbrush. Clean the contacts on the cable, too, but if your charging cable has pins, use alcohol and a cotton swab.
Laurie | Maryland, USA
12-08-2021 22:00
12-08-2021 22:00
Thank you, I will try that.
