02-29-2016 01:33 - last edited on 11-18-2016 12:49 by LanuzaFitbit
I looked for this bug in the ofrum, but couldn't find reference to it. So, if it's been already identified, moderators please move/remove this topic.
for the past days, I am unable to see the charts on the dashboard at all. Checking the broser's console, it seems to be related to the fact that the locale of my machine/browser is english european (en-EU). It used to show the charts just fine until som edays ago ? And since I actually live in Europe, please don't suggest "change your locale / use another browser". I tested in other machines with the same locale set, and the result is the same, no charts.
Thanks
[Update]
Added screenshot for reference
Moderator edit: Removed personal information.
03-01-2016 04:33
03-01-2016 04:33
Hello @cbr600f4 and welcome aboard to our community. I appreciate your observation and indeed. Note that for some locations the Weight chart may not worked as it should but is due to the region coverage, note that not all the countries are not supported. I know you don't want to hear as a suggestion to change locale, but so far this is the only workaround while Fitbit add more countries.
Keep posting in our community and catch ya later.
03-01-2016 04:38 - last edited on 11-18-2016 12:50 by LanuzaFitbit
Hi,
Thanks for the reply.
I understand if some regions are not supported, but this locale is English,
in Europe..... and it worked fine until a few days ago, and I have been
using it for almost a year (or do you remove specific locales support every
now and then ?). So, it's not a case of not supporting this or other
country, I am sure you can quickly check it is a bug. 🙂
Thanks,
Moderator edit: Removed Personal Information.
03-01-2016 04:39 - last edited on 11-18-2016 12:50 by LanuzaFitbit
03-11-2016 01:36
03-11-2016 01:36
The problem persists, the chart pages still don't work ( and they worked well for almost a year), and the browser console shows the same problem, which seems to be related to the locale (which is English !!)
09-14-2016 03:02
09-14-2016 03:02
9 months later, the problem persists, no fix, no charts shown on any browser.
I have "Europe (other)" selected as per the "CHANGING YOUR FITBIT.COM DASHBOARD LANGUAGE" instructions on: http://help.fitbit.com/articles/en_US/Help_article/1536/?q=locale&l=en_US&fs=Search&pn=1
So, I am selecting one of the options that Fitbit webapp has for me to select. Could you please direct me to where it says this option is not supported, of that selecting that option causes me not to be able to see the charts ?
Thank you
09-27-2016 15:15 - edited 09-27-2016 15:17
@cbr600f4 thanks for the follow up! I'm truly sorry to see about this. Rest assured this is being looked into. I certainly appreciate your patience and workaround. Just like you mention, changing the language/region should do it in the meantime.
I also think it would be a good idea to report this to our Support Team!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
