03-28-2017 17:55 - last edited on 03-30-2017 12:01 by LanuzaFitbit
For no good reason my steps are no longer front and center on my dashboard. They are now over to the right and no longer show up unless I go into "edit". The steps have been replaced by "Miles". Suggestions?
03-30-2017 12:30
03-30-2017 12:30
Hello @Mfrags, thanks for joining the Community.
It could have been that you changed your goal to be distance instead of steps. If the main goal is changed, the information showing on the tiles will default to that metric.
As for the location of the tile, on the web Dashboard you should be able to move the tiles around by clicking on them, and dragging the tile around while holding the click. Then you can move the tiles around to fit your priorities or to be on a more visually pleasing order.
I hope you find this useful! Let me know if you have any further questions.
03-30-2017 18:12
03-30-2017 18:12
04-04-2017 13:30
04-04-2017 13:30
Hello @Mfrags!
That is very good to read. Now you can continue getting the information that you need and reaching all of your goals.
If you have a change, you should visit one of your discussion boards. There you can find lots of different topics to talk about with other members of the Forums.
Hope to see you around!
