01-21-2018 16:05
01-21-2018 16:05
My dashboard displays as a grey square on firefox but is okay on MS Edge. I don't use MS Edge , nor do I want to as all my id tracking in integrated into FF. When will Fitbit fix this?
01-21-2018 18:48
01-21-2018 18:48
My Firefox dashboard looks normal. Have you tried killing and restarting Firefox? Better yer reboot?
01-23-2018 05:53
01-23-2018 05:53
You may need to update Firefox or make sure your java is up to date. Do you use extensions? Perhaps one of them is blocking the dashboard. But the main thing is this: Firefox shows the dashboard fine for other users, so there's nothing for Fitbit to fix. Hope you figure out the problem!
