08-01-2017 06:27
08-01-2017 06:27
I tried exporting data using the data export tool under settings and I am not finding a file in my downloads folder. I tried CSV and XLS. I tried using Chrome, IE, and Edge. The Download button acts as if it is creating a file, but no file is created and no error message is presented.
Could there be some type of permissions problem, or could it be putting the file somewhere else?
Thanks
Skip
08-01-2017 18:33
08-01-2017 18:33
I tried this on a computer at home and the export download works as expected. The problem must be a permissions issue with my computer at work or the company network.
Thanks for your reply.
Skip
08-01-2017 16:27
08-01-2017 16:27
@Skip007, I am using Firefox - when I click on the Download button, it opens the dialogue window asking if I want to save the file or open it as a spreadsheet. I also tried it with Chromium version 59.0.3071.109, and it opened a toolbar at the bottom of the screen with the file name which it allowed me to click on to open it. If I do a Ctrl-J in Chromium, it opens the Download list which allows me to select the file from there as well.
08-01-2017 18:33
08-01-2017 18:33
Skip
