05-31-2017 07:36 - last edited on 04-09-2021 11:35 by AndreaFitbit
Where do I enter discount code when at check out?
02-08-2021 08:13
02-08-2021 08:13
05-31-2017 10:37
05-31-2017 10:37
Welcome to the forums!
Where did you get the discount code? If it was from target or else where you need to order from them to enter the discount code
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
01-22-2021 17:13
01-22-2021 17:13
Hello!
My discount code came from Fitbit, they sent me an email since my Versa 2 no longer would work correctly. There is no place to enter a discount code, This is what was sent to me. Use discount code at checkout on fitbit.com at any time in the next 30 days to receive a discount on a new Fitbit device.
01-31-2021 05:42
01-31-2021 05:42
Same exact thing happened to me... bought a device a year later it gave out? Fitbit sells over priced and cheaply made products that are defective😩
02-07-2021 19:48
02-07-2021 19:48
I had the same thing happen with my Versa 2, and can't figure out how to use the discount code on their website!
02-08-2021 08:13
02-08-2021 08:13
04-09-2021 06:52
04-09-2021 06:52
Yup that worked! I wish the customer reps would tell the customers this! Thank you!
07-25-2021 12:18
07-25-2021 12:18
When checking out, there is a tab called "cart summary" or something like that. Hit the drop down arrow and the discount box opens up. It sure why they make it so hard to enter.
