11-08-2021 16:18
11-08-2021 16:18
Fitbit, the nutritional info for a single serving of fresh broccoli is incorrect. App says ione serving of broccoli provides over 14 thousand percent and over 300 percent of my daily requirement for vitamins A and C, respectively.
11-20-2021 06:07
11-20-2021 06:07
Hi Foodlogger56
In case of finding incorrect food entries, it's possible to add a new food item with the correct values (found on the label or looked up on the internet), which appears in our own food list to use.
To log a new food item, on the Fitbit.com dashboard search for any food. A link appears in the menu at the bottom in a yellow text "add new food". Click the link and follow on screen instructions to log the food.
It may be possible to report the incorrect Fitbit food item by contacting the Fitbit support team.
11-21-2021 01:19
11-21-2021 01:19
Are you using an iPhone or iPad for this ?
