01-04-2018 08:09
01-04-2018 08:09
Hi, the HR during work-out on my home-trainer is shown as a flat line in the Windows Dashboard (exercise details) although the data is correctly presented on my Android device.
Please advise.
Leon
01-05-2018 09:51
01-05-2018 09:51
Hello @Ellpee.
That's odd. It is possible that the web Dashboard is not loading everything up correctly from the servers. Let's try logging out and then back so that it reloads everything. Look for the gear icon on the top-right corner of the Dashboard and click on it, then click on Log Out on the menu that comes up.
Please let me know how it goes. If you have any questions feel free to reach out!
01-06-2018 02:34
01-06-2018 02:34
Nope, no change. I checked other exercises that week and they are ok.
However, I notices that the x-axis is based on Km. and the total distance in 1 hour is 0.04 Km (because I am exercising on my home-bike-trainer).
In the exercises that are shown correctly the x-axis is on time.
Hope this helps to solve this issue.
01-08-2018 06:51
01-08-2018 06:51
Hey @Ellpee.
Thanks for reaching back and letting me know it didn't work.
I'd like to take a closer look at what is going on. Could you take a screen shot of the same activity on your web Dashboard and your Android app?
Look forward to your reply.
01-08-2018 12:33
01-08-2018 12:33
Hi Lanuza,
Just a quick update as I am running out of time: yesterday I did exactly the same exercise but with one difference, the coordinate were NOT collected by my smartphone.
The Windows and Android version act now the same: they use the x-axis to display the time (and not the distance which is 0 on the home-trainer).
Let me know if you still need screen shots.
Regards
01-11-2018 08:22
01-11-2018 08:22
Hey @Ellpee.
Thanks for the update. I would definitely appreciate the sceen shots so that I can visualize the situation myself. If you could get them from both ends, windows and android, it would be even better.
