01-16-2018 21:17 - last edited on 01-21-2018 04:34 by LanuzaFitbit
I've not used my Fitbit for quite a while. I signed in to sync/update my data but can not find the little circular arrows I used to hit to begin syncing. Can anyone help? Thank you!
Mari
Moderator edit: format
01-21-2018 05:02
01-21-2018 05:02
Hello @Gramimi.
I suppose you are referring to the Fitbit app, correct? If not, please let me know.
If you are referring to the app, the latest version of the app no longer includes these arrows in order to sync. What you have to do now is to pull down on the main dashboard on the app. Pull down a bit and then let go, you should see that the app will attempt to sync.
Hope this helps out. Let me know if you have any further questions.
