04-18-2017 15:32 - edited 07-10-2017 15:15
Update 07/06/17: This issue has now been resolved, and this fix is retroactive. Now go get that 250!
Update 06/15/17: Engineers are actively working on this issue, and we hope to update you with good news soon.
Update 05/15/17: One fix caused another issue. This issue is not resolved and engineers are actively working on getting it fixed. Thanks for your patience while we sort this out!
Update 05/09/17: This issue should now be resolved, and is a retroactive fix, so if you go backwards in your hourly activity graph, the correct dots should be filled in. Thanks so much for your patience!
Update 4/18/17: Engineers are still looking into a couple of complicated Hourly Activity Goal issues. Here are the issues we're aware of:
-Hourly activity dots don't match up on the mobile app (iOS/Android/Windows) and Charge 2 or Blaze
-Hourly activity dots don't match up on the fitbit.com desktop and Charge 2 or Blaze
If you're experiencing the above issues, please know our engineers are aware and working on this and we'll update you when we have anything to share.
06-14-2017 11:16
06-14-2017 11:16
It's not fixed. Happened to me yesterday.
06-14-2017 23:03
06-14-2017 23:03
Hi Callie!
It has been a month since your last update. You would think that your engineers would have figured it out by now. It is really frustrating! How are things coming along?
~Rita
06-15-2017 08:36
06-15-2017 08:36
@Cricket612 - you would think that, wouldn't you!? In fact, this issue in one form or another has been going on for over a year now. For a significant bug to go unresolved for that long without large software company fixing it seems unheard of to me. Now I've heard that "it's not the same issue" or whatever from Fitbit, but at the end of the day to the end user, it's the same issue - the hourly tracking goals Does. Not. Work. It seems like they've made many attempts, and one fix often breaks something else, but the bottom line is there is obviously a logic problem with their algorithms that calculate the hourly goals. Figure it out Fitbit!
06-15-2017 10:51
06-15-2017 10:51
Hi everyone. This time delay in resolving this issue is frustrating, I'm sure. I wish there was an easy fix, but unfortunately that's not the case with this one. Please check back to the first post in this thread for updates.
06-15-2017 13:53
06-15-2017 13:53
Suggest pinning this thread to the top of various Forums, at least Charge 2, so just maybe some people will see this before starting the 7 thousandth thread bringing up this same issue as if thinking nobody else knows about it.
06-15-2017 14:01
06-15-2017 14:01
This afternoon, I had a problem I have had on other days as well. Specifically, my dashboard has failed to record my 2560 steps for an hour that my Fitbit Charge 2 says I got. For example today, I got my 250 steps between 12 and 1 on my Charge 2 but not on my dashboard.
06-20-2017 17:01
06-20-2017 17:01
More data. The 3-3:15pm slot shows more than 250 steps, as does my Blaze. But on the Android app and website, the 3pm dot is not illuminated.
06-22-2017 12:19 - edited 06-22-2017 12:25
Glad to see that I'm not the only one experiencing this issue. I look forward to it being resolved. Those missing dots drive me crazy lol. I live for the green at the end of the day and I work hard for it, but I keep getting robbed by the app ! LOL ok it's not the end of the world, but it is quite annoying and sometimes frustrating.
06-22-2017 12:38
06-22-2017 12:38
I hope someone from Fitbit reads this post. Through trial and error and testing; I have found the app is looking for around 350 steps to complete the hourly goal; whilst the actual Fitbit is only looking for 250.
If if anyone else is like me and gets up and walks around after your get the notification that you have 10 mins to get your steps and then sits back down to work as soon as your Fitbit congratulates you; you are only satisfying your watch and not the app. The app needs to be reprogrammed to only require 250 like the Fitbit.
06-22-2017 13:11
06-22-2017 13:11
You've confirmed what many have already posted about a count of 350 steps
06-22-2017 13:15
06-22-2017 13:15
Now we just need someone from Fitbit to read these posts and fix it.
06-22-2017 14:02
06-22-2017 14:02
I have not found that it is extra steps it is looking for, just extra time. Or a kick in the head.
If I hit 250 early and sit at my desk, it may not count it right away, but probably will later in the hour. It is when I am alerted to 10 minutes left that I usually have problems with the 250. And in that case, I've found it may pick up the completion without extra steps if I pull down to force another sync. If that doesn't work, I kill the app, relaunch it, and force a sync. That will usually, but not always, get it to recognize the 250. Getting a few more steps does seem to help, but I think that may just be that there was time to get extra steps, allowing a sync to work.
06-24-2017 06:25
06-24-2017 06:25
Is this issue still being worked on?
06-24-2017 17:43
06-24-2017 17:43
Problem here in U.K. Is not solved. Still not registering any activity. Not a happy camper
06-25-2017 19:16
06-25-2017 19:16
I just got my Charge 2, everything is up to date and this has happened 3 times since I got it. Why isn't this fixed yet? It is frustrating when you get something brand new and it doesn't work properly.
06-28-2017 09:24
06-28-2017 09:24
What an amateur outfit.
First device ChargeHR fell apart. Replacement didn't sync properly and following an upgraded device Charge2 still problems with the app not showing the correct details.
Everyone should get a full refund and will never recommend Fitbit as everything is just a load of rubbish.
06-28-2017 09:32
06-28-2017 09:32
I understand this can be frustrating @Fittobetied60 as to why this is not fixed. Well Fitbit thought they did have a fix but it only fixed some users. The problem is in finding why it only affects some and not all, then find a fix that doesbt cause more problems. Then test, test, test, then release the fix, of course we as fellow users really do not know the status of the situation.
06-28-2017 11:11
06-28-2017 11:11
06-28-2017 12:43
06-28-2017 12:43
@Tommo1968 @Shy-Twy Thanks for stopping by!
@Tommo1968 Sorry about your frustration up to this point. There has been many changes done thanks to the direct feedback we have received from our customers as you can see with the interchangeable wristbands on your new Charge 2. Since this issue is from the software part it should be easier to resolve so I can only ask for your patience while this is done.
@Shy-Twy Happy to hear that support was able to assist you with your issue!
I'll be around!
06-28-2017 18:36
06-28-2017 18:36
This has been a known issue for a year???? Serious? I'm having second thoughts about keeping my Fitbit. Either the code is so bad that a resolution can't be found or Fitbit doesn't care much about the functionality of their products. Either way this looks bad.
