09-20-2017 15:07
09-20-2017 15:07
Since the dashboard change I have not been able to check any of my lifetime accomplishments. How do you do it?
09-20-2017 16:23
09-20-2017 16:23
Hello @ChazN,
Welcome to the community!
I can think of two ways to do it:
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
09-20-2017 16:49
09-20-2017 16:49
Thanks but I'm not sure which is the activity+stats tile.
09-20-2017 16:52
09-20-2017 16:52
Ah ha!! got it. Thanks
09-20-2017 17:10 - edited 09-20-2017 17:11
The 'Activity + Stats' tile is the huge 1x3 tile, it looks like this:
On your profile, the section with your lifetime stats looks like this:
I hope this helps.
04-05-2020 05:13
04-05-2020 05:13
Brilliant and thanks.
Always wanted to know if I could do this.
04-05-2020 05:22
04-05-2020 05:22
@DavidS44 I just wanted to chime in that the lower image in the post doesn't "exist" any more. The web profile page was redesigned. You must use the directions on the upper image.
Laurie | Maryland, USA
04-05-2020 06:22
04-05-2020 06:22
04-05-2020 06:23
04-05-2020 06:23
It seemed to work OK for me.
Using Fitbit Charge2.
I find this a really useful log.
08-15-2021 15:14
08-15-2021 15:14
I used to be able to input dates to see how many steps/miles I went in a specific time frame. Right now I'm looking for my total steps/miles from January 1 - August 15th. I can't find the place to do that any more.
08-16-2021 09:15
08-16-2021 09:15
@MarkieBCC Tap/click on the "Log" choice in the header that has the Fitbit logo. Now choose Activities. Tap/click on the "Today" that has the calendar icon next to it. Now you can input your custom date range.
