07-24-2021 14:07 - last edited on 07-25-2021 10:30 by LizzyFitbit
I want to know the exact calories Fitbit is assigning to make sure it matches with another app I use that is linked to fitbit, where can I find that? I do not like this constant changing throughout the day. Just give me a number
07-24-2021 16:55
07-24-2021 16:55
How does Fitbit estimate how many calories I've burned? article.
07-24-2021 18:05
07-24-2021 18:05
07-24-2021 19:04
07-24-2021 19:04
@Lioness3 you will get changing figures throughout the day. If you take a walk for a half hour, that time frame would show more calories burned than if you sat down at your table to sip on some tea. It's ever changing.
07-24-2021 20:20
07-24-2021 20:20
07-25-2021 12:50
07-25-2021 12:50
Hi @Lioness3. Welcome back to the Community Forums. @Odyssey13 Thanks for your great help!
Thanks for your question and as you may know, the calories displayed on your Fitbit device and the Fitbit app sum the calories burned during your activities and the basal metabolic rate (BMR), which is the rate at which you burn calories at rest to maintain vital body functions. The BMR is calculated based on your personal demographics and will be recorded even before getting up of bed, until midnight before they reset.
That being said, if you want to know the amount of activity calories burned on a specific day, you can check the times before waking up and take note of the calories burned from BMR. Use your Fitbit device throughout the day and before going to sleep, sync with the Fitbit app to check how many calories were added and substract them from BMR. You can then compare those calories with the ones recorded on your other app.
Hope this helps.
