03-04-2016 08:50
03-04-2016 08:50
So, I've lost 25lbs but I went and set a new goal and now it says I have lost 0lbs since the date I set that new goal. Is there any way to get it to go back to reflecting my toal weight loss?
02-22-2019 04:38
02-22-2019 04:38
07-12-2019 07:48
07-12-2019 07:48
I cannot find that Plan Summary under the food tab to save my life!
07-12-2019 07:57
07-12-2019 07:57
It used to be at the bottom of the list on the far right of the webpage, under where you enter food. It was also where you can scroll through the part about your food intake for the day, where it says how many calories you have left, there was a hyperlink as one of the words somewhere along that. Sorry it’s not more helpful, I’m on holiday 😆
07-12-2019 08:02
07-12-2019 08:02
This arrow is not there any more! I have looked everywhere.
07-13-2019 20:04
07-13-2019 20:04
Same here!
09-11-2019 05:16
09-11-2019 05:16
Log in to the Fitbit website on your computer. Click on the dashboard tab (at the top). Find the Food Plan tile (mine was on the bottom row, second from the left). Click the “start now” button on that tile. Now you should have a screen similar to the old solution posted on the top of this thread. Click the blue edit button on the “Weight Goal” tab to adjust starting date/beginning weight. (I had to hit the Save/Done button a couple times before it worked. Not sure why.) After my next sync in the app, the adjusted (and correct!!!) weight loss number showed up on my phone. Yay! Hope this helps!!
02-13-2020 06:46
02-13-2020 06:46
Awesome response... lot of threads out there saying this can't be done and obviously it can... I just tried it and it worked! Thx!!!
02-15-2020 00:19
02-15-2020 00:19
Hi this is exactly what I am looking for BUT I still cannot find it. I go to the Food tab but I cannot locate the "Plan summary" . Thanks for your help.
02-24-2020 04:13
02-24-2020 04:13
I am having this issue too - and it seems the UI has been changed since 2016 as there's no place to update the start date that I can find. When I tried to go in to edit it just restarted my goal again and I'm back to square 1 again.
02-24-2020 07:30
02-24-2020 07:30
RitaKay.... OK... I just did it again so it can be done. The trick is to go to the FOOD tab not the WEIGHT tab. Once on the FOOD tab... go to the FOOD PLAN middle left side of the screen. You should see your CALORIES for the day. Scroll through the FOOD PLAN... using the right or left arrows. Next you should see your GOAL ZONE of calories... blue, green, red... scroll once more and you will see your FOOD GOALS to include weight, plan intensity, and calorie deficit (if you are trying to lose weight). Under the calorie deficit is the EDIT button. Click the EDIT button and enter your weight and date you want to roll back to and click NEXT... to scroll through other settings. Hope this helps.
02-24-2020 08:39
02-24-2020 08:39
That worked! Thank you so much. I really appreciate it.
02-25-2020 07:26
02-25-2020 07:26
PinKoona - see my last post... it us under the FOOD tab not the WEIGHT tab.
02-25-2020 07:26
02-25-2020 07:26
dkoble - look at my last post... it is under the FOOD tab not the WEIGHT tab.
04-23-2020 10:06
04-23-2020 10:06
This is the golden answer! Thank you!!😃
04-23-2020 11:16
04-23-2020 11:16
06-24-2021 07:35
06-24-2021 07:35
Thank you so much! This WORKED! I had tried so many times to figure this problem out!
07-07-2021 11:39
07-07-2021 11:39
Hero!!! Thanks!!
07-07-2021 12:25
07-07-2021 12:25
RitaKay - you're welcome 😁
07-07-2021 12:27
07-07-2021 12:27
Very welcome JKT_ - keep working hard and meet your goals
02-28-2023 08:07
02-28-2023 08:07
Thank you so much!!! I’ve lost almost 30 lbs since Jan 2021 and go up and down and like seeing my progress so when I need to cut back on carbs again, I catch it before it is too hard to lose it 🥰
