09-15-2017 16:00 - edited 09-15-2017 16:02
Fitbit update 09/15/17 -- Hello Fitbit Community! With the redesigned Badges and Trophies page, we've removed the Lifetime Weight Badges from the Badges history. You will still be able to view all the other badges on your profile, including the Weight Goal badge.
Please feel free to post any questions in this thread, and we will be happy to address them. Thanks everyone for your understanding as we work to improve the Badges and Trophies experience!
09-17-2017 04:29
09-17-2017 04:29
Why? Can't this be an option to switch on and off? I have a huge amount of weight to lose so I set myself smaller goals but the life time loss badges are something that really keeps me motivated.
09-19-2017 17:36
09-19-2017 17:36
I want to delete my weight loss badges...if i hover over them, as mentioned in other posts, nothing happens? How can I delete them as they appeared on the first day i set up my fit bit.
09-21-2017 09:50
09-21-2017 09:50
Thank you for bringing this subject up. The question I do have is that since I've been wearing the fit bit, I had more than one model. I had the fit bit flex first, then the charge 2 and now the blaze. If any of the badges, that was one and the other to fit bits are use, would it be on record even though I am using the present blaze?
09-21-2017 10:20 - edited 09-22-2017 12:39
@sashah90 Welcome to the Fitbit Community and congrats on your very first post!
In the past, we use to be able to remove erroneous weight goal badges. We even have a help article that provides instructions. However, I tried doing this in my account and was unable to delete my weight goal badges. I'm not sure if this is a bug or intentional. Let me do some investigating and I'll update you when I find out more.
@KraKree You got it! To answer your question about badges, any badges you previously earned while wearing Flex and Charge 2 will remain in your existing account, safe and sound. Now that you have Blaze, you can continue adding to your collection with every new goal you reach. Hope this helps!
09-21-2017 17:22
09-21-2017 17:22
@Angieflibble Thanks for dropping by!
I appreciate your feedback regarding Lifetime Weight Goal Badges. Recent changes to the website badge page bring it into parity with the mobile app, so you’ll now find identical information across both platforms. I will definitely pass your feedback along to our team. Let me know if you have any other questions.
09-22-2017 01:39
09-22-2017 01:39
Thanks. I would have much preferred the parity of having the lifetime weight loss available on the mobile app as it's the one I use the most. They gave enough of a motivation boost that I used to go to the website specifically to check them.
09-23-2017 11:44
09-23-2017 11:44
Hi Carlos--the option to remove erroneous weight loss badges seems to have disappeared for me as well (no trash can appears when I hover over the badge).
Thanks for your help!
09-26-2017 08:34
09-26-2017 08:34
I cannot see any of my badges. I logged in again, but nothing shows up.
10-12-2017 16:26
10-12-2017 16:26
I've always wanted Weight gain badges to be implemented.
10-12-2017 22:20
10-12-2017 22:20
10-16-2017 13:37
10-16-2017 13:37
So I first set a smaller goal because of the large amount of weight loss that I need. Once I reached it, it asked me to set a new goal which made me regain the same 5, 10, 15 .... etc. weight loss badges that I already earned. My first goal I got up to the 35 pound weight loss badge, once I lost another 5 I wanted to get the 40 pound badge but I just got the 5 pound again. I used to delete that I reached my goal weight and it would re-register and make the corrections but now there is no garbage can. So now it keep saying I reached my goal weight and it won't go away.
10-22-2017 13:44
10-22-2017 13:44
Is everyone experiencing the same issue when it comes to deleting weight loss badges? I put my wrong weight in by mistake so it gave me LOADS of achievement badges which I've neither lost the weight for or achieved! It's quite disheartening seeing these on my profile when I know I have a LONG long way to go yet. Is there anyway to remove them? I have followed instructions on previous threads but there is no trash can for me to delete them, I have tried doing this on my tablet, phone and desktop computer! Any help would be much appreciated! Thanks guys
10-23-2017 02:11 - edited 10-23-2017 08:49
Hi CarlosCFitbit
I am not sure if this is related, but I have some weird badge behavior.
It says I have the following badges:
I have lost 9 kgs the last 4½ weeks, weighing myself almost every day (I live for tracking). I have set my goal two times, meeting it once.
I would have expected the following:
Weight goal set: earned 2 times
Weight goal met: earned 1 time
-3 kg Weight loss: 3 times
(I may have adjusted the goal more than once, thus making the extra goal met my fault).
10-23-2017 08:26
10-23-2017 08:26
10-23-2017 08:38
10-23-2017 08:38
10-23-2017 08:51
10-23-2017 08:51
10-23-2017 09:09
10-23-2017 09:09
Well after I hit my goal weight I did end up gaining some weight back so now I'm working on going back to my first gaol weight. My problem is it just keeps saying I reached my goal weight every time I add another weight in even though I'm not at my goal weight.
10-23-2017 09:45
10-23-2017 09:45
10-25-2017 03:35
10-25-2017 03:35
Hi Carlos, it seems that removing incorrect weight badges is an issue. Do you think this will be resolved any time soon. I also put in an incorrect weight (100 pounds less) and now I have a dozen badges I didn't deserve. Thank you.
