03-11-2015 06:06
03-11-2015 06:06
I just received my fitbit. I linked the fitbit to MFP but the food journal I keep in MFP will not sync with the device. Also, I noticed my calorie intake keeps changing on the fitbit. Does anyone know how to fix this problem?
03-12-2015 10:36
03-12-2015 10:36
I'm having the same problem! I deleted both apps and went online and "unauthorized" them and tried again and it's still not working. I'm super confused and frustrated.
03-29-2015 09:19 - edited 03-29-2015 09:19
I just sent an email to them as I have scoured these help forums and nothing has worked 😞
I can see the calories eaten on the computer but not on my phone. Very disappointed 😞
03-31-2015 03:06
03-31-2015 03:06
03-31-2015 03:07
03-31-2015 03:07
04-01-2015 16:47
04-01-2015 16:47
04-01-2015 16:54
04-01-2015 16:54
07-22-2015 10:30
07-22-2015 10:30
I log my food on Weightwatchers. It doesn't sync to Fitbit either. My activity syncs with both WW. and Sparkpeople. I don't want to log my food more than one place. Why doesn't this work/
07-14-2017 09:16
07-14-2017 09:16
The menu options you are listing are not even available from either the app or the website. What am I missing. My food used to sync. Then I stopped adding anything for a while and it doesn't work. Please help!
07-16-2017 10:30
07-16-2017 10:30
Hello @Clwilson5! Thanks for stepping into the Forums.
Please keep in mind that this thread was from 2015 and that the Dashboard and app has had some changes.
As for the situation itself, you mean the food from MFP, right? I'd recommend that you try to unlink your accounts and then link them again by following these steps:
After that, the food could start logging normally once again.
Let me know if you have any further questions.
08-31-2017 08:51
08-31-2017 08:51
I have done this disconnect process twice this morning. Now the exercise data from MFP syncs to my fitbit, but still no food diary. Please help, I am super frustrated
09-01-2017 13:17
09-01-2017 13:17
Welcome to the Community @RonDV.
Thanks for trying the steps I mentioned, I can see how not having the food show up can get really frustrating. Since the disconnect didn't work, I'd recommend that you contact MyFitnessPal about this situation. They should b able to look into what exactly is going on.
Feel free to let me know if you have any further questions.
04-16-2019 16:09
04-16-2019 16:09
I tried that, but it doesn't work for me. It still shows zero, even though I logged all my meals on MFP. If I go to MFP, it does show my sleep, etc., from FitBit, but my meals are not transferring to FitBit.
04-18-2019 09:46
04-18-2019 09:46
Hello @jachang.
Thanks for taking the time to share those details on the matter and trying to disconnect the apps.
In that case I'd like to suggest that you try getting in touch with MyFitnessPal directly. They should be able to take a closer look at what is going on since the integration is developed by them. I'm sure that they will be happy to help you out.
04-18-2019 10:17
04-18-2019 10:17
I've contacted MFP, and they said to contact Fitbit. You say they provide the integration, they say FitBit does. Here is their reply to me:
04-21-2019 08:47
04-21-2019 08:47
Hello @jachang.
I apologize for the delay in my response. Thanks for bringing this up and sharing what they told you.
In this case I'd like to ask you to clarify the situation. Is the syncing between the two not happening or is it delayed? MFP's response refers to a delay.
I look forward to your reply.
04-21-2019 12:21
04-21-2019 12:21
There was a big time lag of several hours for the MFP entries to sync over to FitBit. This happened a couple of times in the past also. It is interesting that in every time it happened, it would be messed up for days, but after sending numerous notices to FitBit and MFP, it would all suddenly begin working again without me doing anything. I'm wondering if, when they are trying to troubleshoot things at their end, they inadvertently fix whatever was wrong.
At any rate, it is now syncing immediately again, the way it used to.
Thanks!
04-22-2019 10:03
04-22-2019 10:03
Well, I spoke too soon. I entered my breakfast into MFP about 11:00a.m., and it is now 1:03p.m., and it still has not synced to Fitbit Dashboard. I keep refreshing my browser, for both tabs, but it does not show up.
04-30-2019 07:40
04-30-2019 07:40
Hello @jachang.
I apologize for the delay in my response. Thanks for sharing those details on the matter.
I'd like to ask if the situation has continued since then or if you have noticed any improvements.
