01-08-2017 07:38
01-08-2017 07:38
03-08-2018 10:52
03-08-2018 10:52
01-10-2017 05:49
01-10-2017 05:49
Hello there @LindaLW! Thanks for joining the Community.
There is no specific sedentary or personalized settings as part of the food plan itself. It probably has to do with the Premium service that we offer. It provides you with additional details from the regular Dashboard. Specifically, the activity report which compares your activity level to all of the other users and gives you some insight into it, letting you know if you've been mostly sedentary or active.
I hope this clarifies your question. If you need anything else be sure to let me know.
01-10-2017 06:44
01-10-2017 06:44
Thanks for your reply, it clarifies the situation. Premium service is not mentioned in any blog where I have seen these settings mentioned!
01-12-2017 05:40
01-12-2017 05:40
Hi @LindaLW!
It's great to know that everything is clear now. If you have the time, I'd suggest you visit one of our Discussion boards. You can talk about a lot of different topics there with other users.
If you have any questions please let me know!
06-03-2017 01:02
06-03-2017 01:02
It's under food plan. Go to log, then scroll down to food plan and click the little cog inside food plan. It gives a description for Sedentary and Personalized.
03-08-2018 09:56
03-08-2018 09:56
Hi i have a fitbit charge 2 i cant find personalised or sedentary plan on mine any ideas ? Regards Roy
03-08-2018 10:52
03-08-2018 11:10
03-08-2018 11:10
Hi Larry i cant find food log how do access it .?regards Roy
03-08-2018 11:20
03-08-2018 11:20
@Carlberg, on the Fitbit.com Dashboard, click on the LOG link at the top of the page. When the Log screen opens, select Food. Then scroll down to the Food Plan and select the Settings gear icon.
03-08-2018 13:15
03-08-2018 13:15
03-08-2018 14:10
03-08-2018 14:16
03-08-2018 14:16
Thank you
03-08-2018 14:19
03-08-2018 14:19
That was doing my head in many many thanks Larry
06-09-2020 05:32
06-09-2020 05:32
One point - I couldn’t find this on the app. But as soon as I went to the internet and logged in, I could see the above instructions.
08-27-2020 02:55
08-27-2020 02:55
I have a charge 2 and also couldn't find it on my phone app. Log in on a desktop computer, select "Log" at top of page. Go to "Food Plan" at middle of page and look for a small blue gear with a drop down arrow next to it. Click the drop down arrow to toggle between "Personalized" and "Sedentary". Hope that helps!
02-19-2021 15:45
02-19-2021 15:45
I am a premium member and am looking for the "gear" mentioned in the following extract from one of your articles:
"...If you’re not into that system, there’s one change you can make to your settings. Click the food tile on your Fitbit.com dashboard and then “See More.” In the Food Plan section, click the gear icon. This is where you can change your Daily Calorie Estimate setting from “Personalized” to “Sedentary.” The sedentary setting starts you out with a low calorie estimate and lets you “earn” more calories by being active throughout the day."
03-21-2021 10:29
03-21-2021 10:29
I have a Charge 4 and do not need premium to access. Go to your account with your photo. Under Nutrition and Weight, select Food even though it does look like you can. Help Me Set A Goal or I Want to set my own goal. Enter weights and then next. It will come up with Easier, medium, kinda hard, hard. Then click next. Helps for those with sedentary jobs to track calories for your appropriate activity level.
03-27-2021 13:09
03-27-2021 13:09
I believe this answer is wrong. I have (and am able to change) the Personalized / Sedentary settings on my dashboard. I am not a premium subscriber.
On the "Food Plan" tile, I can toggle back and forth between the two, and find my cals out / cals left, etc.
03-27-2021 13:19
03-27-2021 13:19
This is not true, your answer is incorrect. In the Dashboard, Food Plan tile, you can toggle back and forth to select (either) Personalized (or) Sedentary, and find your Cal allotment for the remainder of the day.
03-27-2021 13:22
03-27-2021 13:22
This is one of the largest tiles on the Dashboard, simple and easy to find. I'm having a hard time understanding how others have replied to this thread, saying it could not be done without a premium subscription (been doing this since day one). Excellent reply.
