05-15-2018 05:06
05-15-2018 05:06
The past two weeks my Alta has gone off 4 times indicating that I reached my 10,000 steps, but, that is not what registers on my Dashboard. For example, one day my Alta said 11,000 steps and my Dashboard only registered it as 9325. Anyone else have this problem or have a solution???
Thank you in advance!
05-17-2018 05:57
05-17-2018 05:57
Welcome to the Forums @FondaT!
Do you sync after getting the notification on your Alta? It could be that the Alta has counted over 10k steps but hasn't synced to your Dashboard yet so you don't see those steps. Always try to sync your Alta after you get the notification and the steps should be the same on both ends.
If that isn't the case, I'll be moving your thread to the Alta board as it would be better suited for it.
Let me know if you have any further questions.
05-23-2018 03:39 - edited 05-23-2018 03:39
I am assuming that it syncs since I have my phone set to Bluetooth constantly. It also does not register my sleep correctly. It will tell me that I went to bed and to sleep 2 hours after I actually did. I think it's just going crazy.
05-25-2018 11:23
05-25-2018 11:23
Hello @FondaT.
I will be moving your thread to the Alta board, it seems to be related to the Fitbit.
As for what to do, I'd recommend that you try to restart your Fitbit. It could be that something got stuck and a restart could prove helpful.
Please let me know if you have any further questions.
