01-11-2016 19:19
01-11-2016 19:19
01-11-2016 19:23
01-11-2016 19:23
@KLA81 you can use both trackers, just not at the same time. For instance Day 1 you wear your flex and sync it and you wear it part of day 2 and sync, then you switch to your charge. Your charge will import all the steps up to that point from your flex and then when you sync again add whatever additional steps you did. Your post makes it sound like you want to be able to use both the Flex and Charge at the same time. This functionality is not possible.
Please remember to take a moment to mark the post that best answers your question as the Accepted Solution and Vote for posts that are useful or provide quality content.
01-11-2016 19:23
01-11-2016 19:23
01-12-2016 01:55
01-12-2016 01:55
01-12-2016 01:57
01-12-2016 01:57
