09-19-2017 07:07
09-19-2017 07:07
For some 10 days, on my old MAC, I get this message when I try to view my dashboard: "We are aware of an issue with our system, and working to get it resolved." It's followed by a blue X. I have to use other devices to access the dashboard. It seems nothing is really "working to get it resolved!" X"
09-20-2017 06:06 - edited 09-20-2017 06:13
@DrDBB Have you tried another browser, such as Firefox or Chrome? Is this a display issue that happens only on Safari?
And this might make a difference -- are you using the most current operating system that your Mac will support? Are you using the current version of Safari? Fitbit is always "tweaking" the code. Then all of a sudden, older versions of software don't support the new changes.
Laurie | Maryland, USA
09-20-2017 09:38 - last edited on 09-20-2017 11:38 by AndreaFitbit
Yes, it's Safari. That's the only browser that works properly on my very old Mac Mini. I have tried to upgrade, but it won't take upgrades, either. I need a replacement computer, for sure..
Thanks for replying! Blessings, and God in your heart! ¡Dios en tu corazón!
Love like Jesus!
Improve conditions!
Fight for Justice!
Energetically Praise!
Moderator edit: removed personal information.
09-20-2017 10:49 - edited 09-20-2017 12:22
@DrDBB I hope this will help you troubleshoot your problem. If you put your cursor over Safari in the upper left, a menu will drop down. Click on About Safari. A dialog box will open and will tell you what version of Safari you have. The current version is 10.1.2.
I think you will get a definitive answer by contacting Support If you don't have the current version of Safari and cannot update to the current version, then they might tell you that your version just isn't supported any more. Maybe you just discovered a new bug and they ARE actually trying to fix it. Maybe not.
In any case, I hope you have back up of all important files. I looked to see how long Mac minis have been around. I was using a 2008 iMac until this spring. Was planning on replacing it as I had reached the limit of upgrades. I was very lucky to have an external hard drive when it suddenly failed.
09-20-2017 12:08 - last edited on 09-20-2017 12:28 by AlvaroFitbit
Thanks, LZW,
On your recommendation, I've plugged my external drive in. My version is 5.1.10, and it was used when I got it some years ago. The OS version says 2003-2013, but I got it well sometime between those years. It has never accepted an upgrade beyond this one, neither on line nor on a CD; so it has become a bit of an albatross. I haven't had the funds to replace it, but it's days are numbered.
It was a magnificent device at first, so much faster than the PC it replaced! And I loved its compact footprint. I might look for something similar to replace it with.
Blessings to you, and
Love like Jesus!
Improve conditions!
Fight for Justice!
09-27-2017 09:49
09-27-2017 09:49
I accept this response, although it doesn't "resolve" my problem. I basically need a NEW COMPUTER! 😞
