03-08-2020 10:29
03-08-2020 10:29
It did sync but the face will not let me slide my finger to go to the next screen. Just stuck but it recorded my walk this am. Help
03-09-2020 13:10
03-09-2020 13:10
Try a restart do it 3 times
Then A Long Restart
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
If it does not help contact support. Use the Help link at the top of the forum
Wendy | CA | Moto G6 Android
03-09-2020 13:10
03-09-2020 13:10
Then A Long Restart
