02-25-2017 06:45
02-25-2017 06:45
Please find screenshot of weight chart, which does not correspond to the weights entered on the dashboard. The start weight is 3lbs less than entered, and therefore daily weights are incorrect.
03-27-2017 11:14
03-27-2017 11:14
Hey @Malaryn! I moved your post to the Dashboard section since I think it is much better suited to your situation.
I'd like to investigate an fully understand what is going on. What is the latest weight you logged? When was it logged? What is it showing as on the graph?
Knowing all of this will help me find a way to move forward.
Look forward to your reply.
03-28-2017 16:29
03-28-2017 16:29
04-03-2017 14:31
04-03-2017 14:31
Hey @Malaryn! Thanks for the update.
It would seem like the Dashboard is deducting a 0.01 from the weight you entered. I would recommend that you try to enter the proper weight with a 0.01 increase. The Dashboard should automatically move it to be the correct amount in that case.
Please try that and let me know how it goes!
