06-21-2017 16:34 - last edited on 08-20-2020 17:15 by MatthewFitbit
I have set my FLEX2 to auto-recognize swimming and set my pool length at 25 yards. Initially, the number of yards and laps reported on the Fitbit seemed to be accurate, however, lately I have been counting my laps, and there has been an increasing discrepancy. I have been consistently swimming 100 laps in 60 minutes and the Fitbit reports anywhere from 71-90 laps in 60 minutes. Today, it reported 23 laps in 17 minutes! Help!
07-12-2017 05:57
07-12-2017 05:57
@MJBF Thanks for joining us! Try restarting your Flex 2 by doing the following:
1.- Plug the charging cable into the USB port on your computer or a UL-certified USB wall charger.
2.- Remove the pebble from the wristband and press it into the compartment on the charging cable. The pins on the charging cable must align with the corresponding pins on the back of the pebble to lock securely in place.
You’ll know the connection is secure when the pebble vibrates and you see the indicator lights blinking.
3.- Find the button on the charging cable below the tracker compartment.
4.- Press it three times within five seconds. The tracker vibrates each time you press the button. A few seconds after the third press, all the lights will flash simultaneously. This means the pebble has restarted. If you miss the light flash but notice the pebble has resumed charging, that too is confirmation that the restart was successful.
5.- Remove the pebble from the charging cable and insert it back into the wristband.
You could also try changing the length of the pool on the account then save it after this change it back and save again and sync your tracker.
Let me know how it goes!
07-15-2017 14:30
07-15-2017 14:30
I have reset my Fitbit before, but tried it again, along with your suggestion of changing the length of the pool on my account, etc. Bad news: yesterday I swam my usual 100 laps in 60 minutes, and my Flex 2 did not even acknowledge my swim (the same thing happened last week)! I think I have a lemon, and want to return it and try a new one. Please advise.
08-07-2017 13:16
08-07-2017 13:16
I got this fitbit to track swimming. It is really inconsistent on lap counts. I swim 72 lengths, but have gotten counts from 41 to 75. The little graph, however, is accurate. Is there some trick to get it to count, like making sure you swim for a certain time? (Also, it doesn't think sidestroke is swimming!) I was pleasantly surprised to find I am swimming twice as far as I thought, and I checked the calculation to be sure.
08-08-2017 02:08
08-08-2017 02:08
The best suggestion I can come up with is to make sure your turns are clear turns. I use either a tumble turn or a stop and push off type of turn. I am pretty sure sidestroke would be recognised as it is very close to breast stroke. Maybe I'll try it some time! The length of time shouldnt be a problem, as long as you are over the minimum (whatever you have that set at). Lets us know how things pan out.
Helen | Western Australia
08-13-2017 11:49
08-13-2017 11:49
08-13-2017 11:49
08-13-2017 11:49
08-13-2017 12:06
08-13-2017 12:06
08-13-2017 12:06
08-13-2017 12:06
08-13-2017 19:13
08-13-2017 19:13
It is somehow miscounting your turns. Try giving an exaggerated push off at all the ends during a swim one daynand see if it picks that up. Let us know how you go.
08-14-2017 05:33
08-14-2017 05:33
Yeah, I tried all the hints, and still got a lap count of 41 instead of 72. What is really frustrating is that the graph is correct! I am frustrated since I swim the same way and get random counts. The closest it came was 75 instead of 72. I'm going to try letting the battery go completely dead.
08-14-2017 15:19
08-14-2017 15:19
Today I made sure I really pushed off with both feet at my turns; I swam all freestyle and barely stopped. I counted 100 laps (I know I'm right on the count!) in 62 minutes- my Flex2 only recorded 68 lengths! I am beyond disgusted with the poor accuracy of now my second Flex2. From the other comments I've read, this does not seem uncommon. Let's here from a Fitbit customer service rep!
01-14-2020 09:34
01-14-2020 09:34
I have exactly the same issue. 70 lengths reported as 45 by Fitbit. Have you got your issue solved?
Julia
01-14-2020 10:29
01-14-2020 10:29
01-14-2020 11:35
01-14-2020 11:35
