03-23-2017 12:40 - last edited on 08-20-2020 17:15 by MatthewFitbit
My fitbit flex 2 has decided to stip vibrating for alarm or messages & calls. How can i make it start again?
07-07-2017 11:36
07-07-2017 11:36
07-07-2017 19:45
07-07-2017 19:45
If you have tried restRting three times in a row with no improvement, contact Customer Support.
Helen | Western Australia
07-08-2017 09:18
07-08-2017 09:18
I have gone through all the steps recommended on here and my Fitbit still isn't vibrating at all. I use silent alarms a lot so need to get it sorted. Thanks
07-08-2017 18:49
07-08-2017 18:49
Contact support
07-14-2017 03:15
07-14-2017 03:15
I got my fitbit yesterday and I noticed it doesn't vibrate. At all. I tried this solution, but it doesn't work, it doesn't even vibrate as it says it should on the link you gave for restarting the flex 2 (when I press the back button of the charger). It is new, so it shouldn't be damaged. Do you know what else to try?
07-14-2017 04:16
07-14-2017 04:16
Try restarting it three times in a row. If that doesn't work the vibration motor is probably faulty and you will need to contact support or return it to the store you bought it from.
07-14-2017 04:17
07-14-2017 04:17
08-18-2017 16:31
08-18-2017 16:31
My flex 2 won't vibrate...it wasn't doing anything for alarms so I tried restarting it. After I did that it lit up for an alarm but didn't vibrate. And it won't light up or vibrate for messages or calls
08-18-2017 18:24
08-18-2017 18:24
@Em_papa try doing three restarts in a row (one doesnt always do it). If that doesnt work you will need to contact Support. Let us know how yiu go.
09-12-2017 18:41
09-12-2017 18:41
I just got my flex 2 yesterday and it has not vibrated once. I fully charged it for 3 + hours and have even tried restarting it. It lights up correctly for everything but still won't vibrate. How do I fix this?
09-12-2017 20:44
09-12-2017 20:44
Try restarting your tracker. Do it at least three times in a row even if you are not getting any vibration feedback from it. If that doesn't fix it, then you will need to contact support.
09-20-2017 12:04
09-20-2017 12:04
I got my Fitbit at the start of August. It worked fine. About 4 weeks ago now it stopped vibrating. I have tried all of the suggestions a number of times. It still isn't working.
Any other suggestions of what I should do?
Thanks,
09-20-2017 15:03
09-20-2017 15:03
Hi, I have just bought a new one and I am trying to make it vibrate on incoming calls or text message using all the directions that you have posted here but without any success. Also I can mentioned that vibration doesn't work even though, it ist on charger and I am trying to reset it. Should I send it back to your comantly?
09-20-2017 19:47
09-20-2017 19:47
@korgani Contact Support
09-21-2017 21:01 - edited 09-21-2017 21:01
Wish I could help you but I’ve had the same problem - Received my first flex 2 on Aug.12th - vibration worked for about a week! Support sent me a new Flex 2 that I got today - guess what - it doesn’t vibrate at all! Now I have to spend $ to send it back to get a refund! Really disappointed & frustrated! Hope you have better luck than me!
10-17-2017 07:30
10-17-2017 07:30
Hi MarreFitbit, I have had my Fitbit for about 5 months, and this past week I noticed that it was not vibrating for notifications. I have tried all of these suggestions for my Flex 2 and nothing seems to work. My Fitbit is not vibrating at all...not even when I restart it. I have tried a few other tricks that I picked up on this site, but nothing is working. What would you recommend for my next step?
10-17-2017 09:41
10-17-2017 09:41
10-18-2017 04:58
10-18-2017 04:58
Hi, My flex 2 stopped vibrating about 10days ago. I have tried all the tips on here including logging out of everything and restarting it 3 times. It doesn't vibrate at all - not even when restarted. Please can you advise me of my next step. Thanks.
10-18-2017 05:34
10-18-2017 05:34
10-19-2017 15:44 - last edited on 11-08-2019 12:43 by LiliyaFitbit
My flex 2 has quit vibrating. I've done everything on here, the short and long versions. Can someone create an order for someone to contact me about getting a replacement? I've only had it a year and it stopped vibrating a couple of months ago.
