10-24-2016 14:31 - last edited on 08-20-2020 17:15 by MatthewFitbit
Please help, i have had my fitbit for aprox a week. Everything was great but all of a sudden yesterday it has stopped syncing with my samsung phone. This is really frustrating! As far as i can tell the fitbit is still tracking me but just stopped syncing. I have tried everything suggested on the webpage (bluetooth, disconnect bla bla) please help
10-19-2016 14:24
10-19-2016 14:24
10-19-2016 15:42
10-19-2016 15:42
Have you tried restarting your Fitbit? Here are some instructions: Reset Fitbit
10-21-2016 07:37
10-21-2016 07:37
It's nice to see you around the Community @Gwin21, hope you're doing great! Have you tried what my friend @ashley_h suggested? I'd recommend following the steps I've shared here to solve the syncing issue.
Give it a shot and let me know how it goes!
10-24-2016 15:29
10-24-2016 15:29
Same here flex 2 stopped synching today only 1 week old and second replacement for the other that did the same thing. No help with fitbit support they keep you on the phone trying all different solutions over 1 hour finally sent a replacement and now the same problem.
10-24-2016 18:02
10-24-2016 18:02
Hello @Ht29,
Welcome to the community!
By any chance did you recently have an OS upgrade on your Samsung phone to Android 6.0? If so, Google has changed the behavior with bluetooth and the OS. You are now required to enable location services in order to sync. Try enabling that and seeing if that makes a difference.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
10-24-2016 23:12
10-24-2016 23:12
I am having the same issue with my iPhone6. Very frustrating!
10-25-2016 22:20
10-25-2016 22:20
10-25-2016 22:21
10-25-2016 22:21
10-26-2016 02:33
10-26-2016 02:33
10-26-2016 05:23 - edited 10-26-2016 05:23
It's nice to see y'll around the Community @MichaelG1 @Ht29 @Shariwv @SunsetRunner, hope you're doing great! Thanks for helping @PureEvil!
For iOS users, see these requirements first:
If your tracker still won't sync, try these steps:
If your tracker won't sync after the restart, try logging in to your Fitbit account on a different mobile device or computer to help determine whether the original device is the culprit.
For Android users, these are also the requirements:
Depending your Android device, these tips might make syncing easier:
Let me know if this helps!
10-26-2016 05:27 - last edited on 10-26-2016 05:28 by MarreFitbit
None of these steps worked. I call in to speak to the help line. They are sending it on to the engineers.
10-26-2016 05:29
10-26-2016 05:29
Thanks for the update my friend @MichaelG1!
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community, so you can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
See you around!
10-26-2016 09:36
10-26-2016 09:36
10-26-2016 09:50
10-26-2016 09:50
buy a dongle from the flex 1 or if you have one use it it really workes.
10-26-2016 15:30
10-26-2016 15:30
10-26-2016 16:12
10-26-2016 16:12
10-27-2016 18:23
10-27-2016 18:23
10-28-2016 23:53
10-28-2016 23:53
mine stopped syncing. tried everything to isolate that the problem was the pebble. restarted the pebble. now it's working fine. not good! considering its only six days.
10-29-2016 08:24
10-29-2016 08:24
