10-24-2016 14:31 - last edited on 08-20-2020 17:15 by MatthewFitbit
Please help, i have had my fitbit for aprox a week. Everything was great but all of a sudden yesterday it has stopped syncing with my samsung phone. This is really frustrating! As far as i can tell the fitbit is still tracking me but just stopped syncing. I have tried everything suggested on the webpage (bluetooth, disconnect bla bla) please help
10-29-2016 08:44
10-29-2016 08:44
10-29-2016 14:35
10-29-2016 14:35
10-30-2016 02:05
10-30-2016 02:05
I'm having the same problem. It has the delightful additional glitch of briefly showing the number of steps I did at the end of the day (but not active minutes or hours with more than 250 steps), and then un-syncing, and displaying that I did 0 steps. I have apparently done zero steps every day this week (despite being told at least once that it had 'seen' several thousand steps each day.
10-30-2016 05:41 - last edited on 05-27-2019 15:48 by EdsonFitbit
Same here. It finally worked once last night at 7 and again hasn't since. 👿
10-30-2016 06:52
10-30-2016 06:52
10-31-2016 06:43
10-31-2016 06:43
It's nice to see you around the Community @Irishpixie823! Since your tracker receives call and text notifications, your tracker has a Bluetooth "bond" with the mobile device that sends the notifications. This bond prevents the tracker from syncing with another mobile device or a computer.
To quickly and temporarily disable the bond, turn off Bluetooth on your mobile device. You can turn it back on later to resume syncing.
If you no longer use notifications, remove the bond:
You can now set up your tracker using another mobile device or computer. For instructions see How do I set up my tracker?
If that doesn't work, I'd recommend following the troubleshooting steps I've shared here.
Thanks for helping out my friend @gmorrell!
Happy stepping guys!
10-31-2016 07:12
10-31-2016 07:12
10-31-2016 07:33
10-31-2016 07:33
On Android there's a known issue with the latest version of the mobile app that's causing sync issues. They mention it here: https://help.fitbit.com/articles/en_US/Help_article/1345
Android 5.0+
You may be unable to sync your tracker or use call, text, and calendar notifications.
It's mad they released an update knowing it's partially broken.
10-31-2016 12:16
10-31-2016 12:16
10-31-2016 13:32
10-31-2016 13:32
i find it very odd that all of our flex 2 trackers quit working properly on or around the same day...i've only had mine for 2 weeks and it stopped syncing on the 26th...i have followed all the steps except restarting the tracker...what options do we have now?...
10-31-2016 13:41
10-31-2016 13:41
10-31-2016 13:47
10-31-2016 13:47
i just did a restart on mine but it's still not syncing...i'll contact customer support it guess...
10-31-2016 14:04
10-31-2016 14:04
10-31-2016 14:15
10-31-2016 14:15
10-31-2016 14:23
10-31-2016 14:23
i just this minute got off the phone with customer support and they are sending me a new one...i've owned 4 fitbits and i find their customer support fabulous...
11-01-2016 06:16
11-01-2016 06:16
There seems to be a problem with the android app. The pebble is not syncing with the app; saying unable to connect to the server. However, the ios app is syncing and sync is happening through mac too.
11-01-2016 07:51 - last edited on 05-27-2019 16:50 by EdsonFitbit
Not true. I own all iOS. It wouldn't connect with any of my phones, iPad or iMac. The forum kept saying is was an issue with the latest ios10 update, but once I got a new flex 2 I haven't had any problems. There is an issue all around I think with the Fitbit flex 2. Once it finally syncs there is an update for it. I feel like if you can't get it to sync and do the update you're screwed.
11-02-2016 14:57
11-02-2016 14:57
Interesting. Mine hasn't. Time to replace it I think.
11-06-2016 00:44
11-06-2016 00:44
11-14-2016 16:25 - last edited on 11-29-2016 15:17 by LenaFit
My fitbit has not synched with the app since November 10th (its not nov. 14th). There is nothing wrong with my wifi connection, I've restarted my phone several times, and I've made sure the battery is fully charged. This is now the second problem I've had with my fitbit 2 and I'm praying I can find the receipt to return this waste of money.
Moderator edit: Updated subject for clarity.
