10-24-2016 14:31 - last edited on 08-20-2020 17:15 by MatthewFitbit
Please help, i have had my fitbit for aprox a week. Everything was great but all of a sudden yesterday it has stopped syncing with my samsung phone. This is really frustrating! As far as i can tell the fitbit is still tracking me but just stopped syncing. I have tried everything suggested on the webpage (bluetooth, disconnect bla bla) please help
11-14-2016 16:47
11-14-2016 16:47
Hm, mine hasn't synced up yet, either, after two days. That's why I tried the help forum. Mine's a beta version though, so maybe they're working on the issues...
11-15-2016 05:24
11-15-2016 05:24
@gello1028 @AnneBeta Welcome to our Community! Try restarting the bluetooth on your phone and then restart your trackers by doing the following:
1.- Plug the charging cable into the USB port on your computer or a UL-certified USB wall charger.
2.- Remove the pebble from the wristband and press it into the compartment on the charging cable. The pins on the charging cable must align with the corresponding pins on the back of the pebble to lock securely in place.
You’ll know the connection is secure when the pebble vibrates and you see the indicator lights blinking.
3.- Find the button on the charging cable below the tracker compartment.
4.- Press it three times within five seconds. The tracker vibrates each time you press the button. A few seconds after the third press, all the lights will flash simultaneously. This means the pebble has restarted. If you miss the light flash but notice the pebble has resumed charging, that too is confirmation that the restart was successful.
5.- Remove the pebble from the charging cable and insert it back into the wristband.
After this retry syncing your tracker.
Let me know how it goes!
11-15-2016 05:28
11-15-2016 05:28
It's nice to see you guys around the Community @AnneBeta @gello1028, hope you're doing good! If you're using Android device, please follow these troubleshooting steps, these ones for iOS, and these ones for Mac/computer.
Keep me posted!
11-15-2016 06:57
11-15-2016 06:57
I have the following problem for a few days now. I don't think its the tracker issue but more about the fitbit app problem. Lately the flex 2 will only sync with the app if im on wifi connection, but not using my mobile data plan, my internet mobile data plan is fine because i can use all other apps and browse the internet with my phone fine.
I've tried.
- reinstalling fitbit
- Restarting the whole phone
- Disabled / enabled bluetooth
- Closed and opened the fitbit app
-Restarted the fitbit tracker
The day before yesterday suddenly started syncing again with the mobile plan and thought it fixed itself alone but yesterday and today same issue, only syncs over wifi connection. I haven't been able to find a fix for this specific. Im using the latest fitbit app. Also I haven't find any options that says that it should only sync over wifi or alike. Very frustrating.
11-17-2016 02:54
11-17-2016 02:54
Hmmm.... very strange let me say @Rodovalpty! I had this trouble a long time ago, but I found out that the reason why I wasn't able to sync with my cell data plan and just with Wi-Fi was because I consumed over 50% of my plan so my cell data wasn't strong enough to sync with my Fitbit App so I had to switch to Wi-Fi. My first thoughts about what's happening to you is that since I haven't heard something like this before.
By any chance do you have another compatible devices which has cell data plan too you can try syncing with?
11-18-2016 07:16
11-18-2016 07:16
On a similar note... has anyone else experienced steps disappearing? Two days in a row now, it's buzzed to let me know I'm at 10,000 steps (and I know because I checked the light pattern and color and only have step goal and reminders to move turned on) and I'd glance down to see 10,000. Hours later, it would read 7800 or 9200 - after celebrating the 10,000 step milestone! Could it be because I'm doing laps around my apartment complex and going in and out of wifi? If so, they should really patch that bug because I bet a bunch of users do the same thing to get those extra steps in at the end of the day.
11-18-2016 10:30
11-18-2016 10:30
11-18-2016 10:46
11-18-2016 10:46
Okay team - just tried 3 things and it worked!!!
1. Make sure your app is updated - install the latest update if you haven't.
2. Once you've updated, turn your Bluetooth off, then restart your phone.
3. Once started, turn Bluetooth back on, give it 3-4 minutes aaaand voila!
All fixed.
11-19-2016 06:25
11-19-2016 06:25
11-19-2016 09:19
11-19-2016 09:19
Hi guys @Arica77, @GnomesM, @angco, @reebvenners, @SunsetRunner, @daneloverduncan, and @chotothera, how are you guys! It seems that the most of your Flex 2 are syncing properly now. I believe that the issue was due to an old version of the Fitbit app. On the other side, I appreciate the time you took to fix these issues. If this happens again and you have tried all of the steps for iOS and Android devices, I suggest you to get in touch directly with our Support team.
Looking forward to your new comments!
11-19-2016 09:26
11-19-2016 09:26
11-19-2016 10:20
11-19-2016 10:20
Thanks for stopping by @jettybean @mrs_teach @gello1028 and thanks for letting me know what you've done so far! For the ones who still have the syncing issue, I'd recommend following the recommendations that my friend @Thray kindly shares here.
Hopefully that solves your issue as well, keep me posted!
11-19-2016 13:36
11-19-2016 13:36
11-19-2016 17:35 - last edited on 05-27-2019 15:52 by EdsonFitbit
Still having the issue of the app completely erasing my steps after it syncs though. I had to quit a few challenges because it happened twice this week where I had over 24k steps then it dropped it down to 274! So frustrating.
11-21-2016 05:41
11-21-2016 05:41
Hi guys!
@MichaelG1, sounds pretty cool that your new Flex 2 is working without any inconveniences. Thanks for the update! The same to you @MichaelG1. In addition, I have another question, is it your Flex 2 working fine with your tablet? Did you make sure that your have a compatible device? if so, were you able to download the latest version of the Fitbit app?
@Arica77, thanks for getting back to me! on your iOS, do you have the latest operation system installed?
Catch ya' later!
11-21-2016 06:55 - last edited on 11-22-2016 04:11 by HeydyF
This is working on my iPhone and iPad....
Moderator edit: deleted personal info
11-21-2016 08:14 - last edited on 05-27-2019 15:51 by EdsonFitbit
Yes I do. If only happens when I have more than one device connected. What's the point of being able to have more than one connected if it erases all of you steps?! So frustrating. I refuse to disconnect my flex 2 ever again since it has so many issues connecting in the first place. This is a bug that has been happening for over a year now.
11-22-2016 19:16
11-22-2016 19:16
11-22-2016 19:19
11-22-2016 19:19
11-22-2016 19:42
11-22-2016 19:42
