10-24-2016 14:31 - last edited on 08-20-2020 17:15 by MatthewFitbit
Please help, i have had my fitbit for aprox a week. Everything was great but all of a sudden yesterday it has stopped syncing with my samsung phone. This is really frustrating! As far as i can tell the fitbit is still tracking me but just stopped syncing. I have tried everything suggested on the webpage (bluetooth, disconnect bla bla) please help
09-21-2017 06:19
09-21-2017 06:19
Fantastic that they are replacing it! Good lucknwith the new one.
Helen | Western Australia
09-24-2017 11:52
09-24-2017 11:52
I have been having sync problems since I got my Flex 2 in May 2017, so I guess, from looking at all these comments it's not unusual.
I wanted to run it from my laptop, but after a few weeks it became unreliable. Reset etc etc. Got a replacement bean (thank you customer service, you were very helpful and I appreciated your advice etc), but still no joy.
I had a new laptop delivered (W10 like the last one). Nothing from the app. I had previously found that the app works fine on my old android tablet (hudl2) in France, so I uninstalled from the UK laptop and tried my Acer tablet in the UK. Bingo.
Maybe it's just flaky on laptops. Maybe designed principally for Android/tablets. Jut going by the evidence, guys.
09-24-2017 19:01
09-24-2017 19:01
@GJFrance From my personal experience my trackers work far better with my phone and tablet than with my laptop (windows 10). I dont even bother with the laptop any more. It was causing too many grey hairs!
10-08-2017 06:26 - edited 10-08-2017 06:30
HI
The steps to sync are helpful. However I find I have to follow them almost every time I sync my fit bit flex 2. It appears I may not be the only one. Does fit bit track these messages for feedback so a fix can be looked at?
10-08-2017 06:32
10-08-2017 06:32
Yes the mods keep an eye on what appear to be new bugs and report them to the appropriate department. I dont know if this is a bug or not.
10-08-2017 06:35
10-08-2017 06:35
10-08-2017 07:02
10-08-2017 07:02
Hi. I don't think they trawl every message, but I found their support very sympathetic and helpful. My Flex2 works fine with the app on my tablet. I've uninstalled and disconnected from my laptop. Try customer support, and, just a thought, I had an update of hardware etc recently. It was 24.24.30.2 so make sure it's up to date. I only noticed it because it told me on the app. All the best.
10-08-2017 13:28
10-08-2017 13:28
11-24-2017 22:15
11-24-2017 22:15
I’ve taken every step and yet my Fitbit still refuses to sync in. Please help!!!!
11-25-2017 02:06
11-25-2017 02:06
@HKizer what are the steps you have tried? There is no point me repeating things you have done.
11-25-2017 04:36
11-25-2017 04:36
12-30-2017 12:21
12-30-2017 12:21
I was having the same issue! What ended up working was reinstalling the app, and acting like I was setting up a new device, but instead, clicking "replace Flex 2" and going through the setup again
01-16-2018 06:37
01-16-2018 06:37
Flea2 has stopped syncing with my iphone
01-16-2018 08:40
01-16-2018 08:40
Yes mine too. It last synced at 8:46 am. I've restarted it and walked around but still not fixed. Called Fitbit. They suggested I turn Bluetooth off and on. That didn't work so they had me turn off my phone and back on again. That worked. Yay.
01-17-2018 01:19
01-17-2018 01:19
01-17-2018 07:02
01-17-2018 07:02
Same problem . . . but my Fitbit Flex2 will not Sync at all. (Laptop, Desktop, SmartPhone). I had no previous problems with it syncing with any of my devices. I took app off of my SmartPhone; no change. It will not sync to either computer. I am only trying to use my laptop but problem still exists. I suspect it has to do with Fitbit and Software issues but do not know this. I only wish it works!
01-17-2018 09:43 - edited 01-17-2018 09:44
Hi, I had the same issse. To fix it, on my phone, I turned off Bluetooth, waited 20 seconds and turned on again. Then I turned off my phone and back on again. That synced it to all my devices. This was advise from Fitbit help desk.
01-17-2018 16:24
01-17-2018 16:24
01-18-2018 03:21
01-18-2018 03:21
If it won't sync, I would definitely get in touch with Fitbit especially if it used to sync or if it's a new unit. They are very helpful.
But what finally fixed mine was a new phone. My 5-year-old phone (bought new) hadn't been one of the latest models when I got it. I found upgrading to a newer model (three models back from the latest) did the trick. No more issues.
02-12-2018 12:35
02-12-2018 12:35
My Flex 2 stopped syncing about a month ago, but then suddenly started again after a couple of days. I didn't think any more about it until the same happened three days ago, and it hadn't synced since. Having tried pairing with a different device, turning Bluetooth on and of, restarting the phone, and just about everything else I could think of or find from Google, I finally tried resetting it as per the link on the first page of this thread (put Flex 2 in charger, press button on charger three times within 5 seconds). At the second attempt it worked. When I said sync from the app, after a delay of over ten seconds, it suddenly synced once more. My worry is that some people have had so many problems with this that they have had to ask for a new Flex 2.
