All Lights Flashing Rapidly on Flex 2 - won't reset
ANSWERED
All 5 of my lights on my flex 2 are flashing quickly, and it won't reset when I put it on the charger.
I've tried forgetting it on my Bluetooth app on my phone, forgetting it on my Fitbit App, and rebooting my phone. I don't think it's a syncing problem. Is the pebble dead?
1 BEST ANSWER
Accepted Solutions
If you havent already tried, restart it several times in a row. If that doesnt fix it it sounds very ill. If it is under a year old contact support as it should still be in warantee
Restart your tracker
Community Council Member
Helen | Western Australia
72 REPLIES 72
Thank you. I've tried restarting it. I'll have to call support.
The reset doesn't work by pushing the back button three times. Can anyone tell me what customer support said as their reply time is two days?
That isn´t an answer. And if it´s just over a year old? trow it away, just like that?
Looking for a response as well having the same problem.
Hey @Rattljazz I hope you are doin' great! And @dofa, let me give you a warm welcome to the Community!
If you haven't, I'd like you to try to restart your Flex 2 by following the instructions in this post. If the issue persists, I'd like you to try to set it up as a new device, and while doing this, please keep it plugged into the charging cable.
Let me know how it goes!
Heydy | Community Moderator, Fitbit
I didn’t throw it away. I contacted FitBit and they were able to replace it
since it was still under warranty. But it was a catastrophic failure of the
part.
The dynamic principle of fantasy is play, a characteristic also of the
child, and as such it appears inconsistent with the principle of serious
work. But without this playing with fantasy no creative work has ever yet
come to birth. The debt we owe to the play of imagination is incalculable.
It is therefore short-sighted to treat fantasy, on account of its risky or
unacceptable nature, as a thing of little worth. — Carl Jung
 Hey @coyotedreaming, I hope you are doin' fine! I appreciate the time you have taken to contact our Support team and sounds great that they have replaced your Flex 2 and get you back on track.
If you have further questions or comments, let me know!
My flex 2 lights are flashing and i cannot get it to reset by pressing the button at the back.  The bluetooth is also not picking up the device.  Is there anything else we can do to try reset it?
Hey @SunsetRunner, welcome aboard! If your Flex 2 won't restart, I suggest you to wait until the battery drains out, then fully charge it and restart it again. That might turn off the lights on your Flex 2 and get it back to normal.
Not sure how if i would be able to see if the battery is low because all
the lights keep on flashing
Thanks for your reply @SunsetRunner! Does your Flex 2 still syncing? If so, that is how you can check out the battery level.
All lights are flashing on my Flex 2. It also wont restart when pressing the back button 3 times.
Tried it but its not working all lights are still flashing.  Really have been having no help form fitbit.  I was always a loyal fitbit supporter but their support service is non excistant.
ohn i have the same problem still and nothing is working.
Moderator edit: merged reply
Hey guys, @JohnAtkins and @SunsetRunner, I appreciate your replies! Considering that the issue with your Flex 2 persists, I have escalated your case with our Support team so they can further assist you, so please keep an eye on your inbox.
Thanks
You are more than welcome @SunsetRunner! Please let me know how it goes!
I'll be around!
Following as mine is flashing rapidly and won't rest. What do I do next?
I believe it is a fault in the fitbit. Resetting didn’t work so I contacted Fitbit direct and after a lot of communication they agreed to offer me a replacement or new different style for 50% off the price of my Flex. Not ideal given that it was a fault but better than nothing.
