02-27-2020
03:49
17:08
02-27-2020
03:49
17:08
Since the app updated yesterday on my iPhone, all the lights on the Fitbit Flex 2 are flashing, and the Fitbit will no longer connect to Bluetooth. I can't use the Fitbit.
02-27-2020 09:36
02-27-2020 09:36
when ur fitbit is plugged in charging there is a button on the back of the charger try holding it down for 5 seconds as that will restart your fotbit and it should connect again ive had to do it a few time with my husbands
02-27-2020 21:33
02-27-2020 21:33
This week it is difficult to get the device to sync to the phone and it does not show on the phone when it is charging- always shows 60%, does not show active minutes. I wonder if the problem is with Fitbit Co no longer producing flex 2 and no longer supporting it on app?
02-28-2020 02:31
02-28-2020 02:31
Thank you. I tried this myself. The lights start flashing as soon as I plug the fitbit into the charger. When I press the button the lights go out, only to restart the flashing as soon as I release the button. I will keep trying 🙂
02-28-2020 02:33
02-28-2020 02:33
Thank you. I have wondered this myself. No longer supported, so they want us to purchase an up-to-date model. Too expensive for me to do that. I shall keep trying the "reset" option 🙂
02-28-2020 07:03
02-28-2020 07:03
03-02-2020 08:08
03-02-2020 08:08
03-29-2020 18:53
03-29-2020 18:53
Try plugging the Fitbit Flex 2 pebble into it's USB charger. Push the square button on the back of the pebble 3 times within 5 seconds. You should feel a vibration and the lights should go out after each push. After that the Fitbit Flex 2 should start working again. Mine didn't. Mine isn't under warranty any longer. I hope yours is.
