05-28-2021 17:29
05-28-2021 17:29
I noticed yesterday that my device buzzed , meaning I had reached my 10000 steps . (I was exercising at the time ) But half an hour later when I went to the app it only showed 10042
There is no way I only did 42 steps in the following 30 minutes
today my device shows 3 lights meaning I should be atleast over 4000 steps but when I go to the app
It says that I’m at 3900
how can I get my app and device to sync up??
05-29-2021 16:07
05-29-2021 16:07
Hi, @Michelle2279 , if your Fitbit and your app indicate a different number of steps that simply means the Fitbit has not synced to the latest number. Usually this will be a matter of simply waiting a short period and it will happen automatically, so is nothing to worry about. However, you can usually force a sync by going to the account screen (click on the person icon top left of the opening screen) and choose sync now.
If sync now does not force a sync, it can help to log out of your Fitbit app and log back in again. That will usually cause your steps to update - but do make sure that you know your email address and password that you use for Fitbit.
I hope this helps. Welcome to the forums!
