03-05-2018
15:53
16:59
03-05-2018
15:53
16:59
I'm using an acer chromebook and have the dongle plugged in, but it wont sync. I am on the dashbord website there is no way to manually sync.
03-06-2018 00:15
03-06-2018 00:15
I'm afraid fitbits do not work with chromebooks. You can't sync via the web dashboard on any device and the software required to sync isn't available for chromebooks. There's a feature request to add support for these here https://community.fitbit.com/t5/Feature-Suggestions/Add-Chromebook-as-a-supported-device/idi-p/43669... if you'd like to vote for it.
In the meantime do you have a compatible phone you could use? The list of supported devices is at www.fitbit.com/devices
03-06-2018 00:15
03-06-2018 00:15
01-08-2020 09:11
01-08-2020 09:11
I tried resetting my fitbit 3 time in a row on my phone. I t still does not give me my sleep data. It went from giving me scores and rem, light, and deep sleep to nothing.
Best Answer11-16-2020 13:11
11-16-2020 13:11
My Chromebook is currently charging my Fitbit and I am amazed, but if I pick it up it stops charging and only continues when on a flat surface like a table
