05-11-2017
07:52
16:59
05-11-2017
07:52
16:59
Someone please help me. I want my old dashboard back. I went to settings, nothing there! I have silent alarms already set in my Flex and can't find them anymore with this new dashboard to change them!! Does anyone with Fitbit care how much I hate this NOW!!
06-25-2019 21:17
06-25-2019 21:17
Your posted solution to finding alarm setting doesn’t work. There is no “tile” in the top right. Of the screen. There are no + signs that relate to silent alarms. What is the scoop? I am a Charge 2 user with an iPhone. Help!
06-25-2019 22:18
06-25-2019 22:18
Fortunately Fitbit gave me the solution. Click on your picture in the top right and then click on the Fitbit you are using in the list. All the settings should come up and silent alarms in about 4/5 down the list 😃
06-26-2019 06:52
06-26-2019 06:52
Best Answer06-26-2019 14:35
06-26-2019 14:35
Am I just being dumb, what tile tracker icon? My top right icon only takes me to messages & notifications. I can't find the alarm anywhere.
Best Answer06-26-2019 14:39
06-26-2019 14:39
If you swipe down to sync your fit bit, click on the charge3 where the battery is under it and the alarm settings will come up.
06-28-2019 04:24
06-28-2019 04:24
Thank you!!!
Best Answer06-28-2019 21:12
06-28-2019 21:12
This is infuriating. I cant find alarms anywhere on the new dashboard. The instructions: "go to alarms". Where the heck is that!?!, ",click in the upper right,corner". Where on the message box. Nope. This new interface is terrible!
06-28-2019 21:13
06-28-2019 21:13
What plus sign? I cant find it. This dashboard sucks!
06-28-2019 22:03
06-28-2019 22:03
Mine has no plus sign. I click on my picture and it lists the fitbits I’ve had. Click on my current Fitbit and silent alarms is 4 down the list. 👍🏻
06-29-2019 04:17
06-29-2019 04:17
Best Answer06-29-2019 04:20
06-29-2019 04:20
Definitely different. Glad it works 😃
Best Answer06-29-2019 08:02
06-29-2019 08:02
Best Answer06-30-2019 16:44
06-30-2019 16:44
Oh Bless You!
Ive been fighting with this since it switched over and it’s been angering me every night that I couldn’t adjust my alarms. I remembered the forums tonight’s and gave it a shot and found your response. Sure enough it took me right to my silent alarms! Thank you! Now to get rid of my stress induced migraine and I’ll be top notch!
07-01-2019 16:04
07-01-2019 16:04
Thank you, very helpful! Couldn't find this anywhere in Fitbit's support.
07-02-2019 12:47
07-02-2019 12:47
thanks for the info, I have been messing about for a few hours with no joy. got my alarms back up and running, as I use them every day. thanks.
Best Answer07-03-2019 20:32
07-03-2019 20:32
Thank you so very much. You saved me.😃
Best Answer08-08-2019 19:06
08-08-2019 19:06
And how do I set the alarm when I haven't been able to see anything clearly on my device screen in a month even though I only got my Charge 3 in February and the new app interface doesn't have "silent alarms" anywhere to be found?
Best Answer08-08-2019 19:17
08-08-2019 19:17
08-08-2019 19:26
08-08-2019 19:26
Thank you! 😍
Best Answer08-09-2019 14:34
08-09-2019 14:34
Thank you!!!!!
