03-07-2024 23:42
03-07-2024 23:42
I want to change my Dominant hand but when I tap today and device I don't get my devises as next page, is there a work around
03-08-2024 03:54
03-08-2024 03:54
Hi, @Circussam , I would recommend making sure that you have the most up to date version of the app. From the opening screen of the app tap the small icon top left (watch and smart phone icon). On the next screen you should see your Flex 2. Tap on that and the first option you see should be “Wrist”. There you can set whether you wear it on your dominant or non dominant hand.
If you do not see this option I would recommend checking for updates for the app. If necessary, delete the app and re-install it. You will not lose any data doing this, but do make sure you know the email and password associated with your Fitbit account.
03-08-2024 03:54
03-08-2024 03:54
03-08-2024 23:55
03-08-2024 23:55
I had been really worried about potentially "Undoing" any good I had done in fixing it all. Your reply helped me take my courage in both hands I just kept pressing stuff and Woohoo the wrist bit came up and I could get it sorted. I have no idea what I did differently but that doesn't matter I just needed to get it sorted and on my wrist. Now seems to be working, which is fab.
Thank you so much for taking the time to reply. Have fun.
