02-23-2024 14:43
02-23-2024 14:43
So I have a current plan set to have a 750 calorie deficit each day. Currently 10.30pm so not much time left in the day to burn calories and not planing on consuming anymore. My current cals in shows as 1841 and cals out is 2703 so this is higher than my 750 target. I currently show over budget. Since over budget shows in red and under budget blue I would have taken over budget to mean that I have not met my calorie deficit of 750 and under budget to mean I have but does Fitbit calculate it the other way and says you are over budget if your deficit is more than your target deficit?
