01-22-2019
09:57
17:15
01-22-2019
09:57
17:15
When I go to Goals and select Activity it only gives me the Calories option. How can I get the steps to display?
Thanks.
01-22-2019 14:35
01-22-2019 14:35
Welcome to the forums!
Are you using the drop down on the dashboard under setting?
Hope to see you around the forums!
Wendy | CA | Moto G6 Android
Best Answer01-17-2020 18:24
01-17-2020 18:24
I am having the same problem. If I go to Today, then Edit, I have no choice except calories burned. I don't know where the drop down you described is at. I went under my account under activity and exercise and both do not have any drop downs. If you could give step directions on where to find it, I would appreciate it!
