03-05-2017
13:01
16:59
03-05-2017
13:01
16:59
Up until this morning my flex was displaying my steps as my main goal. However it has changed itself to show Calories as the main goal.
i have looked at my main goal and it is set to steps. Whatever I change this menu too the display remains as calories.
can someone please advise?
tks
10-03-2020 04:16
10-03-2020 04:16
Mine is gone the very same no steps tile whatsoever
Best Answer03-07-2021 02:11
03-07-2021 02:11
This was only helpful comment!! Thank you, I set it up!!
Best Answer03-07-2021 02:18
03-07-2021 02:18
For me, I clicked on the top LEFT corner on the picture of my account, than clicked to "Set up a device" and chose my phone, since I don't have a watch.
After, I went back to main screen with calorie count, press and hold calorie icon, when just below it steps icon shows up, went on "x" on calorie icon, and clickednon steps icon which then comes into focus on the screen.
So this is detailed explanation, as I was talking to my grandma 🙂 hopefully, it will be helpful.
01-01-2022 15:01
01-01-2022 15:01
Same question here, there is nothing about steps at all on my dashboard
Best Answer01-29-2022 14:43
01-29-2022 14:43
Agreed, I've only had mine since Christmas and it constantly fails to sync. Tried all the suggestions, nothing works. Contacted support and they told me to add another device (replacing existing one) and the first time, that worked. But the sync issue started happening again within days, and now that isn't working to fix it. It finds the device, but won't connect. So I have to stay on the existing connection - where I now have the same problem as above. I see CALORIES at the top where I used to see STEPS, and I can't figure out how to fix that. I'm referring to the app, not the dashboard on the computer. Very frustrating this FitBit, I really thought I'd like it, but it's frustrating me to no end.
Best Answer01-03-2023 00:03
01-03-2023 00:03
I have no step title in my app.
02-06-2023 06:46
02-06-2023 06:46
There is no “steps” tile below and I can’t seem to find any other way to fix this.
02-06-2023 08:18
02-06-2023 08:18
I tried to start the fix below but found that in addition to steps missing replaced by calories on my iPhone, steps are no longer even a tile option on my sense 2 at all. I was walking this morning when steps suddenly changed to calories. I tried re-pairing my sense 2 and nothing changed. Next, I found the solution here to try. Neither worked.
02-06-2023 08:28
02-06-2023 08:28
Same here, cruzansuz. There is not even a Step Tile in my options to move. This issues started today (Feb. 6, 2023).
Best Answer02-06-2023 09:00
02-06-2023 09:00
Same issue. Starting about 3 days ago my fitbit would not stay connected to my iPhone. Today, steps were replaced with calories. Steps no longer even show up as an option. I've reloaded the fitbit app and having the same problem. I've now shutdown the fitbit and will try again in 30 minutes or so.
Best Answer02-06-2023 09:26
02-06-2023 09:26
have cals only .....no sub goals
Best Answer02-06-2023 09:27
02-06-2023 09:27
did not work
Best Answer02-06-2023 09:29
02-06-2023 09:29
have no small steps
Best Answer02-06-2023 09:36
02-06-2023 09:36
Thanks. My sleep info has disappeared from displaying on the app also. Any thoughts on how to get it to display?
