10-01-2016
15:58
16:59
10-01-2016
15:58
16:59
10-02-2016 01:49
10-02-2016 01:49
Best Answer10-02-2016 02:05
10-02-2016 02:05
10-02-2016 02:27
10-02-2016 02:27
Best Answer10-02-2016 05:38
10-02-2016 05:38
Thank you for posting, I was perplexed by the problem this morning.
I use my silent alarms to take medication at the same time every morning, this morning stuffed me right up with the daylight saving changes.
The same thing is happening for me, try to set an alarm and it sets back an hour. I will unistall and see if this helps.
Best Answer10-04-2016 14:38
10-04-2016 14:38
@Takeis @SunsetRunner Welcome to the Fitbit Community! What it needs to be done here is to make sure the time on the Fitbit app is correct. I recommend following this workaround about the time zone on iOS devices. After doing that, the time or any time issues should be corrected and you should be able to set up the alarms properly with no issue.
@Erin87 It's great to have you on the Community! I'm very glad to hear that you are back on track now. Thanks for sharing the workaround that fixed the issue you were experiencing.
Let me know how it goes! ![]()
Best Answer10-04-2016 15:02
10-04-2016 15:02
10-10-2016 14:01
10-10-2016 14:01
I went to hawaii so set my flex to GMT zone. While there my flex quit working (it was old) bought a new one yesterday but cannot get time zone back to CDT! I know where to do this and how to do this but am only being offered cities (all over the world) in GMT. Please help - really messes up my data.
Best Answer10-10-2016 14:59
10-10-2016 14:59
@JDebra Welcome to the Fitbit Community! I recommend selecting the time zone that best reflects the one you are in. I recommend trying these steps:
This should work, but if for some reason it doesn't, these tips about travelling with your Fitbit tracker should also help.
05-28-2018 23:20
05-28-2018 23:20
This did not work for me. Any other advice?
Best Answer07-16-2018 14:37
07-16-2018 14:37
Thanks, but Nope -
It's currently Mon at 5:45 PM, my One still say's Tues at 5:45 PM. All day sync is on, tried the 'changing time zones' From ahead 12 hrs (sync) to behind 12 hrs (sync) back to local (sync) - no difference (other than the time in hours obviously) to network time
Sync 'a moment ago' (5:32), software Ver 6.64. I'm still at a loss.
Best Answer07-16-2018 14:46
07-16-2018 14:46
And OBTW, SantiFitbit - the date stamp on your post is 2 months before I was given the "One" (sounds kind of 'Matrix-y', "The One"), but I followed the advice anyway thinking you've been here before and copy & pasted a previous response 🙂
"SantiFitbit, 10-10-2016 14:59"
Next suggestion?
Thanks - Rat
Best Answer07-31-2018 14:45
07-31-2018 14:45
great first try got it
Best Answer03-14-2020 13:18
03-14-2020 13:18
My Iconic still has not changed ti Daylight Savings Time,. Ive synced several times
