05-16-2019
12:08
17:15
05-16-2019
12:08
17:15
I have just got a Samsung Galaxy A40 and cannot connect my Flex 2. Is this phone not compatible? I have tried restarting the pebble and starting the process again without success. Any ideas would be gratefully received.
11-29-2019 04:10
11-29-2019 04:10
Hi
Yes I spent a similar time with fitbit- bearing I mind one of the first questions they ask is what phone do you have - it took them nearly an hour to tell me it wasn't compatible. Very unhelpfully told to use my old phone- which is a Microsoft phone that they are now not supporting!!!!!!!!- double epic fail on behalf of Fitbit. A40 operate s the new Android Kernal software which is the up and coming operating system so hopefully it will be resolved soon.
11-29-2019 04:13
11-29-2019 04:13
I have the same thing, it works with my iPad but not my phone. Haven't been able to sync since 19 November so I think the bug fix update on 18 November broke something. I still get call notifications tho even though the app cant find my fitbit?!?!
12-15-2019 00:37
12-15-2019 00:37
I can not pair my charge2 with my Samsung A40. As soon as I enter the 4 figure code, he keeps on seeking, ending with 'not possible to paire, Some features work, other do not work.
12-15-2019 03:35
12-15-2019 03:35
12-15-2019 09:20
12-15-2019 09:20
Same here, got a new Galaxy A40 and everything works great except cannot pair my Fitbit Alta HR, it gets to the pairing and I put the 4 digit code into the app and it then fails. Very frustrating as I have a great new phone and no connection to my fitbit device. Please please Fitbit could you update the app or device so they are compatible.
12-15-2019 09:34
12-15-2019 09:34
I'm sorry to say but that's not going to happen. As you will see from several topics on this board it's been an issue for months and fibit won't d8x it. They have even stop replying to post. Which is good in a way as at least there not giving people false hope as they were in the early posts on this issue.
12-16-2019 06:37
12-16-2019 06:37
I'm having the same issue and am very disappointed. I wish i'd checked before i changed my phone. I have always had mid range Samsungs and never had an issue before. I thought it would be fine as it should just work through the bluetooth.
I am looking at the possibility of switching to a Samsung tracker, but would rather this was resolved.
12-16-2019 06:40
12-16-2019 06:40
Change to the Huawei band 3 pro , haven't looked back. Excellent piece of kit and no issues connecting to a40
01-07-2020 10:13
01-07-2020 10:13
Hello,
I have also bougt a A40. And now i can 't connect my charge 2 . Its very sad.
I get the code on my charge 2 to connect and then it goes wrong.
Isn't their no solution ?
01-07-2020 11:42
01-07-2020 11:42
01-07-2020 12:15
01-07-2020 12:15
I had the same issue but since my Samsung system update a couple of days ago my flex 2 now works perfectly
01-07-2020 12:38
01-07-2020 12:38
01-07-2020 12:45
01-07-2020 12:45
01-07-2020 12:57
01-07-2020 12:57
01-08-2020 03:42
01-08-2020 03:42
Hi Fitbit (Google?),
Any update on this. I understand that smoothly pairing with all the new phones coming on the market is difficult. However, the problem has been ongoing for months now. I have tried all the tips and tricks reported in the thread and the fitbit app does not seem to be able to even detect the Inspire HR watch to pair although Samsung is a major smartphone provide, the Android OS is up to date, the bluetooth connection works for other devices !
What alternatives or workarounds do you propose? Is a reimbursement possible?
Thank you,
Laetitia
01-08-2020 03:47
01-08-2020 03:47
Fibit is the new nokia . Was market leader and took there eye of the ball like nokia and will be lost for years to come. Look at a Huawei band pro 3 or garmen if you want something that works.
03-31-2020 00:44
03-31-2020 00:44
Mine is the other way got A40 last Thursday paired nicely now since yesterday it can't even fine it to pair? What do I do now?
04-01-2020 03:16
04-01-2020 03:16
I am having problems also. I have Galaxy S5, Android 6.0.1. I see that this is not on the list but I've had my fitbit for 2.5 years and it used to work fine. Now it won't sync because bluetooth can't find it. Has the entire system been updated since I purchased my Flex 2? It's just disappointing that something that used to work before doesn't now. Is there anything I can do besides buy an new phone?
09-18-2020 23:03
09-18-2020 23:03
I've had my flex 2 SUCESSFULLY connected to my SAMSUNG A40 for two years, but have just replaced it with a new A40 and now it will not connect.. what's changed??
09-25-2020 09:17
09-25-2020 09:17
I have the same problem and i dont want to do factory because i already a fitbit inspire set up
